SWR Moving Around
Discussion in 'CB Radio Forum' started by fastwillie8568, Aug 16, 2018.
  1. fastwillie8568
    fastwillie8568 Bobtail Member
    Aug 16, 2018
    New president McKinley cb, new president Iowa antenna, new painted bracket, new cable, and connectors. SWR jump when I move the mic they go up or down. Please advise any help would be great. thanks
  3. Ridgeline
    22,724
    123,366
    What?
    When you move the mic around, the SWR goes up/down?
    Is the SWR meter external?
    If not, get one and see if this happens.
    Timin770 Thanks this.
  4. Zango606
    Zango606 Bobtail Member
    10
    Aug 8, 2018
    Hammond ,IN
    Grounding issue?
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    The McKinley doesn't have a normal Meter to check SWR. It has digital readout that says 10, 12, 13 etc. (10 = 1.0 and so-on...doesn't show the decimal ) it also beeps to the value, like if you have a 1.0 SWR then you get one long tone...farther away from 1.0 you get beeps...slower the beep, worse the SWR is...you also don't push the Mic button, it's automatic in SWR Mode...
    What I would do is get in a open area to do your check...if it's still doing what you say then I would first check all my coax and Mic connections... Haven't ran into that problem with mine.
    Now if your checking SWR while driving around, then what your saying is normal...SWR doesn't stay constant when moving.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    LOL The beeping deal is like the rig expert /zoom feature..
  7. Gadfly
    Gadfly Medium Load Member
    674
    323
    Aug 18, 2006
    That would be my bet: he's got RF in the cab with him and grounding issues. Unless, he is moving when he's checking SWR-that would also cause it. That is because when an antenna moves thru a fluid environment, it encounters different things: other vehicles, buildings, the ground underneath--even moisture can affect it. So you need to be sittin' still to check it and ground, ground, ground! Make those grounds short as possible.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Almost have to be a grounding problem if just moving the mic up and down causes it to jump...BUT, I cant remember ever having a issue where SWR jumped around by just moving the mic around...even back when I was running a 16-pill....I had RF all over the place but still no jumping swr just moving the Mic...(I think he's driving around)
  9. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    I have the same CB and the SWR is not accurate. It was showing 1.8:1 for me and it was a perfect 1:1. Use a real SWR meter.
    That being said, my SWR was jumping around too and it was because of a bad ground. If you're in a truck with a fiberglass cab you really almost have to use a NGP (no ground plane) antenna kit. The performance isn't quite as good as a normal antenna on a good metal truck, but it will be far better than the performance of a normal antenna on a fiberglass truck that you can't get a good ground on.
    A quick test to see if you have a bad ground. Put the CB on SWR and listen to the beeps. Close all doors and park the truck away from anything around the antenna. Now, grab the base of the antenna where it mounts to the truck. Just grab that sucker and hold it. If the beeps get faster then your SWR is going down when you grab it and that is a direct indication of a bad ground.
    Zango606 Thanks this.
