At 350K miles, I thought I would drain & change the oils in my gear boxes. Everything looked good, no chips, teeth pieces or chunks.
I remember the last time I had this done, it cost me like $350 with labor and all... Well let me tell you something, it cost me $405 for 5 gal of syn 50w, 5 gal of syn 75/90 & 2 gal of Lucas (for the rears).My oil distributor guy told me that he was told that it was going up in June, something about the base stock costing more
So.... you better get it done now if you need to change out your boxes before the price goes up.
BTW, the rears take just shy of 3.5 gals ea & the trans about 4 gals.
Have fun like I did....![]()
Syn oil prices going up
Discussion in 'Ask An Owner Operator' started by Starline, May 2, 2012.
350,000 MILES? I change mine at 100,000. but as long as it works for you. is the 50 wt. full syn ?BigBadBill Thanks this.
Why would you need Lucas when running a synthetic? If you want thicker lube in the diffs then just run a mineral based lube and Lucas.
I really have no problem when you change the lube... to each his own. But Eaton recommends a 500,000 mile lube change when using synthetics. Oh well.
We do the same, 500K on synthetics. I about took a dump in my britches when I saw the invoice for a 55 gal drum of differential oil at almost $2000.
Wow man that is just crazy! Just curious, how does that compare to say 10 years ago when diesel was around a $1 a gallon, what would that 55 gallon drum have cost back then?
Couldn't tell ya, 10 years ago I'd only have been 12 years old.
I've grown up in the family trucking business. Last year we got in a bind when our maintenance director quit so I had to jump out of the truck and run the shop till we hired a replacement and I got him trained and up to speed. -
Wow, you're lucky to be in a situation like that. I can tell from your posts that you're taking full advantage of it and learning everything you can.
JDP Thanks this. -
I am very lucky. Enjoying my last couple weeks of college up here at Marquette in Milwaukee before I graduate on the 20th. Going to go back OTR for a month or so before going inside the office. It's about time for my old man to retire
like that will ever happen.
I can't wait to get back there. 3rd generation company, should be fun for my brother cpape and I. -
Your rears hold 3.5 gals... it was cheaper to buy the lucas @ $50 then it would be buying another 5 gal @ $158 + tax.
You change Dino oil @ 100,000... syn at whatever the mfg recommends... 250K to 500,000
I run Meritor rears...
Linehaul, Every 500,000 miles (800 000 km), or every 4 years, whichever comes first
Intercity, Every 250,000 miles(400 000 km), or every 4 years,
Heavy Haul, Every 100,000 miles (160 000 km), or every 2 years,
I had 350K miles and its been over 5 yrs since it was changed... I actually wanted to check rears for broken teeth or excessive wear as I thought I was hearing some noise. Its better to catch a problem early.... and since the oil was darkish... its better to put fresh oil in rather then old.
I also replaced the suspension valve today and readjusted the height. my problem might have been the valve, but in any case... everything concerning the drive-line has been replaced or inspected. Trans and rears are still original.
