T600 HELP!
Discussion in 'Ask An Owner Operator' started by kw600, Mar 12, 2012.
  1. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    So here we are in the good ol' state of california when driving rite before sunset,get to terminal and BAM the light on the odometer gives out. It won't come back for the life of it. Opened up the dash, all there is are wires wires and more wires, all labeled. Anyone know how to change the light bulb or get it to work?been playing with it for a while and getting nowhere, please help! Its a kenworth t600 2003:::
  3. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Did you check the fuse?
  4. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Yup, if theres a litbulb its the problem
  5. rollin coal
    rollin coal Road Train Member
    13,704
    28,207
    Mar 29, 2008
    TN
    There are regular incandescent bulbs in there. I forget the size number. You can get them in truck stops. My rpm and speedo lights went out a couple of years ago. Was easy to change out. As I recall there is a socket on the back of the gauge that the bulb is enclosed in. You twist til some tabs line up then it pulls out so you can get to the bulb. Hope it helps..
    kw600 Thanks this.
  6. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Rollin coal thank you!!!!!!!!!!!!!!
