T600 , jumping up and down going 65 mph
Discussion in 'Kenworth Forum' started by Jakebanman, Sep 23, 2019.
  1. Jakebanman
    Jakebanman Bobtail Member
    Sep 23, 2019
    Truck jumps up and down going speed limit, have new U joints, new carrier bearing, new drive tires, new shocks tried several different steer tires! At my whits end with this thing! It feels like it's coming from the front of the truck but I cant find anything loose. Any advice be appreciated
  3. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    You can either keep throwing parts at it or make one phone call to Mike Beckett at MD Alignment.
  4. Luke4780
    Luke4780 Bobtail Member
    4
    back side of rims clean? Seen it before to where there was so much brake dust caked that it would cause a heck of a vibration.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Did you CAT the rig and see where your weights are?
    In certain situations she will buck on you.
  6. speedyk
    speedyk Road Train Member
    1,837
    2,471
    Apr 8, 2015
    Cab leveling valve.
  7. Jakebanman
    Sep 23, 2019
    Replaced that too along with cab mounts
    speedyk Thanks this.
  8. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    I don't understand the "jumps up and down".
    Is it a really bad vibration, or is it just an unnecessarily rough ride when it shouldn't be E.I you hit a small bump, and the truck tries to throw you to the floor?
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Jack up one wheel at a time and turn it by hand, then see if it moves back by itself, if it feels like a steer, I would start with them.
    It could be a brake hub out of balance, tire out of round, or even not properly mounted.
    While you are checking the steers, check the kingpins and bearings.
