T660 ABS tractor ABS light
Discussion in 'Kenworth Forum' started by HoneyBadger67, Aug 27, 2019.
  1. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    OK....so I've done my due diligence in searching the interwebs and this site but can't seem to find the answers I'm looking for.
    Situation is this: 09 t660
    The tractor ABS light is on and constant. This just started after a particularly hard rainstorm. Cruise doesn't work, (even parked to keep oil pressure up), and jakes operate as though I've activated the brake switch. What could cause the computer to believe I'm applying the brakes when I'm not? And why is this causing the ABS light to come on?
    I've tried pushing the ABS test button on the kick panel but it isn't doing anything.
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Update: high idle works with parking brake released but not when applied.
  4. Jenn72
    Jenn72 Medium Load Member
    604
    1,454
    Jun 7, 2019
    Had this happened a couple of times after it has rain. Check the connection on your air hose. Disconnect and wipe it off. If that doesn't work, i also have a wire brush and have cleaned the connectors on both ends (tractor and trailer side)Turn off your tractor for a couple of minutes. When you turn it back on and start moving it should go back off. Hopefully this works for you.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Airlines would affect the tractor system?
  6. Jenn72
    604
    1,454
    Jun 7, 2019
    The airlines triggered the abs code on my tractor
    HoneyBadger67 Thanks this.
