T660 headlights replacement
Discussion in 'Volvo Forum' started by Gurpal, Feb 10, 2020.
  1. Gurpal
    Gurpal Bobtail Member
    Got new headlights, but old ones screws are not opening up , they are rotating from within body, if I cut the screws how can I put new ones , or any other ideas
  3. Jbarto
    Jbarto Bobtail Member
    5
    Feb 20, 2018
    Legit same exact situation....not sure what to try. Going back to the truck early tonight to try vise grips on the bolt ends and a wrench and heating the nut up‍♂️
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    They're just coarse thread screws that go straight into the fiberglass. They suck, I know. Get the screws out the best way you can, patch the fiberglass, mark where the holes belong using the old light and the dirt under the hood as a guide and drill new (small) pilot holes.
    For patching the 'glass, you can get what you need at Wally World. No need to pay body supply store prices. The loose weave batts and some resin, (the hardener is under the lid) will do the trick. Pull enough strands out of the batt to plug the hole and use a chip brush to dab and saturate the fiberglass with the resin. Put a piece of tape across the backside of the hole to prevent the resin from forming a glob on the other side. File everything (somewhat) smooth, mark and drill your holes, Bob's your uncle.
  5. Jbarto
    5
    Feb 20, 2018
    I just used gorilla glue and rethreaded them in.
  6. 86scotty
    86scotty Road Train Member
    4,700
    12,901
    Aug 27, 2017
    Appalachia
    What truck are you guys talking about? Kenworth or Volvo? T660 is a KW model.
  7. Jbarto
    5
    Feb 20, 2018
  8. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Put this in the Kenworth forum and you may have better luck.
    86scotty and HoneyBadger67 Thank this.
  9. Jbarto
    5
    Feb 20, 2018
    Lol post was already answered. Im not the OP either.
  10. Jbarto
    5
    Feb 20, 2018
    U do bring up a good point tho
    86scotty Thanks this.
