t660 idle shutdown? (werner truck)
Discussion in 'Werner' started by wanttotruck, Oct 8, 2014.
  1. wanttotruck
    wanttotruck Light Load Member
    79
    51
    Mar 5, 2014
    DFW
    Hey guys I just got assigned a t660 and can't figure out how to get it to idle. I've seen several threads on here suggesting to chock the wheels and stuff, but what I was told from a mechanic at the terminal was set the hand trailer brake twice and turn on the cruise...
    I somehow got it to work last night, but today I just can't figure out why it won't work.
    Its almost 100 outside, so it should be fine.
  3. tmb0507
    tmb0507 Medium Load Member
    357
    197
    Aug 11, 2012
    Folkston, GA
    If you have the dumb optimized idol thingy flip you shifter to high and turn cruise on once the engine shutdown pops on your dash override it by setting your cruise rpms should bump up jump in sleeper and set the temps on your idle control in sleeper should be good to go thays how works on my truck but its freightliner but hopeing optimized idol works either way
  4. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Most are just by setting the cruise. Click once up, another should set the high idle.
  5. snowwy
    snowwy Road Train Member
    20,618
    13,341
    Jul 6, 2009
    in the FL's. the yellow valve has to be out. cruise has to be on. tap the resume/accel button and idle jumps up to 800.
    sounds like what the mechanic told you also. and you just simply forgot. :biggrin_255:
  6. Jigbuilderone
    Jigbuilderone Bobtail Member
    Oct 22, 2013
    Dallas, TX
    A light on the instrument panel shaped like an engine with a wrenching the middle of it will come on about 15 seconds before shutdown , when this light comes on appy the foot brake until light goes out, this works on my 660
    wanttotruck Thanks this.
  7. Koolguy
    Koolguy Light Load Member
    88
    12
    Jun 9, 2012
    Trenton,NJ
    In a t660. To idle, u need a trailer or chock the wheel. But basically. Set the trailer brakes and release the tractor brakes. It should idle then.
  8. X-Country
    X-Country Medium Load Member
    645
    462
    Mar 27, 2014
    locate the black or nude colored nipple appearing ambient temp sensors and wrap them with hand warmers (get the 12 hr life ones), use electrical tape to hold it on the sensor, then wrap in a bandana and slide it all in a warm insulated winter glove (i.e ski gloves or similar).
    she will idle all night long. but just know you fleet manager can see your idle % and they will nag you about it. cya and send a message saying too cold for the bunk heater to work properly and that you have to idle.
    usually one temp sensor on the frame rail chassis on driver side in the back and if theres a second one it will be mounted up inside the front bumper area or to the front crossmember at the bottom.
  9. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    Why am I losing air in my secondary tank whenever I set my idle control? Everything is fine when there is no key in ignition. I drive I believe it's cascadia
