T680 AC issues!
Discussion in 'Kenworth Forum' started by Woodruffism, Jun 26, 2015.
  1. Woodruffism
    Woodruffism Bobtail Member
    So the AC blows, and it blows cold. Just not from the dash vents. It works great out of the defrost vents, floor vents, and everywhere in the sleeper but when switched to dash vents. No air at all! I am stumped! Has anyone encountered anything similar? Any information is good information at this point.
  3. truckin4fun
    truckin4fun Light Load Member
    85
    39
    Dec 16, 2009
    Shelbyville Tn
    Don't have any problems with mine but I always run my on auto
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Sounds like a blend door that is not moving properly.
    Woodruffism Thanks this.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    there is an actuator in the (box) that controls the blend doors positions. it has a tendency to screw up. or the linkage for the doors is stripped out. set it on the position you want then turn the truck off for a while. 20 minutes or so. start back up and see if it is blowing out the vents you want. if so then it is the actuator that is bad.
  6. Mdennis
    Mdennis Bobtail Member
    Just spent thousands of dollars changing the main mod box that controls where the air moves
    2015 T680 just out of warranty
    So disappointed in KW
  7. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    The gears which turn the blend door are made of plastic. Sometimes a foreign object gets jammed in there and ends up tearing those up. Sometimes the actuator itself takes a ####.
  8. tommygra
    tommygra Bobtail Member
    yes im having same issue, but no vents open, not even defrost
  9. tommygra
    where can I find this actuator?
  10. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    What year truck?
