T680 air compressor
Discussion in 'Kenworth Forum' started by drewfarmsllc, Mar 5, 2023.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    84
    32
    Oct 18, 2008
    South Carolina
    Got a 2020 t680, Cummins isx 15, auto trans. My air compressor seems to be coming on a lot. It does it sitting still and going down the road. We have checked all brake chambers and lines and can't find a leak. We checked with truck running and turned off. Press the brakes and the needle won't drop??? Does the transmission use a lot of air? Is there something else I need to look for??
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    You have an airleak somewhere. Get soapy water and spray everything down. Including transmission lines and trailer lines if it's the same trailer.
  4. JB7
    JB7 Road Train Member
    1,037
    1,830
    Dec 13, 2022
    Laurel, MD
    What is seems to be coming on a lot? How often is it cycling? Time it. At idle with no brake applied cycle should be 2-3 minutes. Were the brakes released when the truck was sitting still and you checked for leaks? Possible compressor unloader malfunction. Did you check the air dryer?
  5. AModelCat
    164,992
    If the compressor is cycling on/off more often than it should with the truck just parked bobtail and idling and you don't notice the pressure dropping off on the gauges, most likely a leak somewhere between the compressor and the wet tank or in the governor/unloader circuit.
  6. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Do you mean it’s purging frequently? Trace the signal line from the air governor to the compressor unloading valve… you probably have a break in it somewhere.
