T680 battery access
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Midnightrider909, Feb 28, 2017.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I just got this truck and the 1800 watt inverter is not acting the way it should. If I run a string of Christmas tree lights it does just fine but if I try to run my 700 watt microwave it shuts off and then goes right back on. It does this every time I try to operate the microwave.I'm thinking it's a loose or corroded electrical connection. I'd like to check where the inverter is wired to the battery but I can't figure out how to Get access. It looks like there's some bolts holding on the side trim pieces where the steps are. do I have to remove those in order to get access to the underside and the battery? If not how do I get access to the battery.
  3. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
    6 allen head bolts on driver side steps if memory serves me right
    Midnightrider909 Thanks this.
  4. Ridgeline
    22,753
    124,087
    Midnight, you an owner or just a driver?
  5. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Driver. Need to refi the house first, then buy a truck and go o/o.
  6. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    All the ones I've seen, you use a 17mm six point socket.
  7. 91B20H8
    2,946
    3,315
    Oct 17, 2012
    U may be right, i haven't pulled mine in 3 years
