My company has me in a 2019 T680. I have a Connex 3300 that I want to run in it. I have several different ideas I'm gonna try for mounting so I think icI got that covered.
What I'm needing help on is powering the big radio. I just talked to my preferred CB shop and they told me I need at least 10 gauge(8 would be ideal) wiring directly to the battery. Anyone able to tell me how to run the wiring? I'm planning on hanging the radio directly underneath the factory mounting location so I'd want to run the wires up through there and out to the radio. If I use a heavy duty 3 pin power cord with an inline fuse, would I need any other fuses in the power supply?
T680 questions
Discussion in 'CB Radio Forum' started by jjmck82, Nov 2, 2020.
Page 1 of 4
A 3300 only draws about 15 amps max
12 gauge is plenty
No need to go to battery -
Wait till you key up and voltage drops on 12ga....N3TD3ViL Thanks this.
CONNEX3300HPB Specifications . Power Output 50+ Watts PeP Modes AM / FM Frequency Range 10 Meter 28~29 MHz Length 10 1/8" from heatsink to bezel Length 11 1/4" from heatsink to control knobs Width 7 7/8" Height 2 3/8"
Current Draw 7 Amp
Fuse Size 10 Amp
12 gauge wire is plenty -
I've already bought the 8 gauge wire and inline fuse holder on the advice of a very good CB shop. Cost difference between it and 12 gauge is insignificant and I really don't see how a slightly heavier cable will hurt.
Did I mention it's been peaked and tuned? I'm told 100 watts is not out of the question. I'm prepared at least so I feel ok about that. -
Specs are not far off from my stryker..Try it and see what happens..Take in account the crap wireing and connections that truck manufactures use you will see a voltage drop..When voltage drops so does output....Feed the radio what ever it needs and get what the radio was designed to do..
Hell i would up the wire ga for a cobra 29 outta the box,might be over kill but still...
Found this nust to show..
that radio will do a max of 55-60 wattsN3TD3ViL Thanks this. -
Good plan..
We dont know whats been done or if that 100 is rms or pep but i would assume its pep..
Page 1 of 4
