t800 Jake Brake Problems
Discussion in 'Kenworth Forum' started by mdrake67, Jan 13, 2020.
  1. mdrake67
    mdrake67 Bobtail Member
    5
    I have a 2006 Kenworth t800 Heavy Wrecker with a c15 CAT we just picked up and the jakes are not working at all. When you flip the switch the retarder light comes on and the switch has power but the jakes do not work at all on any stage. Pulled the valve cover and inspected the harness and no chafes or broken/unattached wires. Checked the relay and its working. When hooked up to a Texa Laptop under parameters it shows engine retarder-disabled but doesn't give a way to enable it. Under all the retarder settings there is a Retarder-off/low/medium/high switch setting but the value shows J1/P1:23 & 40 and I can not figure out what this means. Any help would be appreciated. Thanks
  3. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Ok so sounds like you pin pointed it. Says it’s disabled in computer so you will have to go to cat or find a local truck shop that has et and reenable it
