T800 Radiator replacement recommendations?
Discussion in 'Heavy Haul Trucking Forum' started by RogerShilling, Jul 17, 2022.
  1. RogerShilling
    RogerShilling Bobtail Member
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Hello. I have a T800 with an N14 Cummins, and am needing a better radiator. I changed my OEM 3 row last winter due to it having significant external corrosion, and went with a 5 row from my local KW dealer. I was told the 5 row is the cats meow, and I would never overheat again. I'm not impressed, and feel it actually does worse at cooling than the 3 row I had.
    I haul big round bales of hay. 10' wide, 15' tall. Usually weigh 83-85k, but those of you that have done it can confirm hay pulls terrible hard. Would prob be comparable to pulling a 100k load with normal wind drag. I am set at 525/1850 with a power box on top of that, and use all the power I have probably 80% of the time. I load in eastern KS, and haul to western Kansas, which is 5.5-6 hrs. Then turn around and come home empty.
    The dealer has graciously said they will give me full credit for the 5 row, as it is not performing like it was advertised.
    What radiators do you heavy haul guys like to use? 4 row with dimple tubes? Go back to the 3 row OEM? This truck stays on the highway 99% of the time, it's not a field truck that will be getting dirt and hay in the fins. I do drive a few gravel roads (slowly) depending on where I load my hay from.
    I would like to be able to pull hard in 100-105 degree temps without overheating. KW dealer says there isn't a radiator out there that will keep up with the demands I am putting on it. I find that hard to believe. I have talked to Pittsburg power, PDI, and several radiator shops, and I get the feeling that there would be options that can keep that engine at it's operating temp of 180-200 even when pulling hard for long periods of time.
    I know it's not a thermostat issue (have checked, replaced, checked again, etc), or a water pump or belt problem. The 5 row just isn't getting the air flow thru it I need it seems, which is what I have heard others say is a weakness of the 5 row design.
    Thots?
  3. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    How did the Oem handle overhearing and heavy hauls?
    kylefitzy Thanks this.
  4. AModelCat
    165,019
    Strange. Most folks running the T-800 out in these parts are running 140k lbs in the summer and never hear of issues with overheating with the OEM radiator.
    All the shrouds/guards are still in place? Fan not installed backwards?
    Goodysnap Thanks this.
  5. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    I would get to 210-220 on hot days. Kinda hard to exactly nail down where it was, as I have since installed a digital temp gauge, and I just had the OEM gauge with the OEM radiator.
    I know how it does now to within a degree. The other day it was around 95 outside, and I got it to 216 before backing off of it.
  6. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Fan is installed right. It kicks on right at 200, and works well. Since it has warmed up this summer I have gone to turning fan on manual, and making it run 100% of the time while loaded. It definitely helps to do that.
    Fan shroud is there, but I do believe there are a couple rubber strips that are missing that used to run vertically along both sides of the radiator. I know they would help prevent air from bypassing the radiator, and I need to install them and possibly do some other things to help force air thru, not let it go around. But I feel like while those things may help, they are not the root cause.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Why did you back out of it? Is your fan not working? My 3406e has a 700 file and my fan doesn't even kick on until 217. It puts out like 9 something to the crank and 7 something to the wheels with a dimpled 4 row. Also has a "high performance" CAC. It does pretty good but if I had to do it all over again I would take it to radiator shop I trust to build one custom.
  8. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Fan is working fine.
    Guess I figure when Cummins says 180-200 operating temp that maybe I shouldn't be trying to see how far above that I can make it go.
  9. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Didn't realize it was so low for an N14. Find a good radiator shop and they'll set build you something proper.
  10. Dirk Diggler
    Dirk Diggler Light Load Member
    56
    170
    Jul 15, 2022
    Are you sure it’s not just dumping too much fuel? What the cac and air filters look like? What’s the egt’s? Also wasn’t it like 110 in Kansas a couple days ago? May just need to back out of the pedal and don’t beat your horse to death.
  11. J.R.
    J.R. Light Load Member
    65
    184
    May 17, 2012
    WI
    My N-14 is similar setup in 379, same also on anything over 80 degrees easier to leave fan on.
    I think the glitch is the thermostats not fully opening until 190*, and then fan on at 200*.
    Figure out how too get ecm fan on at 210 would probably help alot?
