T800 rear end vibration
Discussion in 'Kenworth Forum' started by RogerShilling, Feb 23, 2022.
  1. RogerShilling
    RogerShilling Bobtail Member
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Hello all. I have a 2003 T800 daycab that is giving me fits. A little history, truck specs, and what i have tried-bought truck used in 2016 with 600k miles, has 740k now. It has an N14 Cummins, FRO16210C trans, 3.90 rears on AG400 8 bag suspension.
    It had super single rear wheels, we quickly changed to duals for our work. Transmission was replaced around 3 years ago. Engine inframed 2 years ago. All new u-joints and complete driveline balanced. All new brakes. All new shocks.
    All new motor and transmission mounts. New torque rod bushings. New axle bearings. Installed Centramatic wheel balancers last week. Ride height set at 9" from bottom of frame to middle of axle. Nothing I have done to this truck over the years has changed the vibration at all.
    Pretty sure its coming from the front rear end, because when i had the interaxle driveshaft out for its balance and new joints i jacked it up in the shop and got it up to speed. Vibration was there, with just the front rear powered.
    Now, to try and describe the vibration. Its a low frequency, pulsing vibration. I can pull the gear shifter towards me, taking up the slack, and vividly see when and how much its doing it. Gong down the road at 65 mph, it will throb the shifter 4-6 times in a 3 second timeframe, be still for a second or two, then throb again. Its terrible bobtailing, bad empty, slightly less noticeable loaded. But 95% of the time, its always there. I say that, because one day last summer i drove home from a western KS feedyard empty, 330 miles, 5.5 hrs, and it never did it once. Shifter was steady as a tree, no throb at all. But most of the time, its there. Some days worse than others, but usually its there.
    What I think I have eliminated as possible problems- its not tires or rims, due to a complete swap. Not a driveline issue, or u-joints. With the centramatics not helping a bit, is it possible its not a vibration, but something else causing a throb, and causing the rear of the truck to hop up and down?? Bobtailing you can see the right back of the frame hopping up and down.
    I have not been into the rear ends to inspect them, to be honest I am young and not sure what I will find when I open them up and don't want to get in over my mechanical head.
    I have multiple videos of this problem, and would love to share with someone who is a genius as these problems. It wont let me upload one here, says they're too large. Contact me if you think you can solve it, and I'll figure out a way to share a video.
    Would appreciate any and all opinions and advice. Tired of throwing parts at it, and not changing it a bit.
    Thanks
  3. Big Road Skateboard
    7,098
    40,281
    May 2, 2021
    I'm your huckleberry...
    JK, so since vibration changes with load, surely ride height has been verified as correct? 9"?
    I would verify that height is correct. Are you sure you don't have a tire issue?
  4. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Have no idea about the inches, but loaded air bags have to be at the 1/2 to 3/4 of their total heights to the best of me know.
  5. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    If you have a YouTube account load it there and post a link to it here.
  6. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Well here's a couple thoughts.
    Have you checked:
    Pinion bearing
    Carrier bearing/ support bolts/ driveline angle
    None of the U-joint caps are spinning
    Wheel bearing end play
    Loose u bolts shifting on axle
    Broken spring
    Loose airbag
    Leaf spring bushings
    Leaf spring/ hanger bolts
    Leveling valve
    Axle alignment/ tire wear/ tire height
    Out of round rims/ tires
    Bent frame
    The eight bag suspension has a lot of pivot Points. Have you checked that none of them anywhere have play?
  7. 201
    201 Road Train Member
    12,781
    26,304
    Apr 16, 2014
    high plains colorado
    Harmonic balancer on the engine? I heard that can cause vibrations that seem to come from somewhere else. Maybe a bent axle ? Who knows where that truck has been, good luck, if it's any consolation, get a new speedometer head, as by the time you're done finding it, theoretically, you should have a new truck. And a stern warning to anyone else wanting to buy a truck today, repair shops THRIVE on this kind of stuff,,you can't win.
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    One of our W900s with AG400 was doing the same thing. Drove us nuts for months. Was the rear axle rolling in the saddles on the axle tube. Found it when we had it in the shop, in gear with the brakes off, and gave it a couple little nudges with the forklift and saw the axle move.
  9. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Ride height is set to spec given to me by my local KW dealer.
    Cannot be a tire issue. Didn't change when I switched to duals. And actually just a couple weeks ago it got a new set of drive tires, didn't change anything.
  10. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    Will try that, hadn't thot of that option.
  11. RogerShilling
    26
    4
    Apr 13, 2017
    Westphalia, KS
    We put on a new harmonic balancer at time of the inframe.
    I have thot about a bent axle. But repair shops around me say axle shafts never bend, they just break. ?
    201 Thanks this.
