T880 charging issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by hkerekes, Feb 14, 2021.
  1. hkerekes
    hkerekes Bobtail Member
    10
    Jun 12, 2010
    Truck has an x15 and is still under warranty but the dealer is closed and was hoping i might be able to diagnose it myself.
    The alternator is not charging at all. The battery connections are fine and not corroded, i didnt put a multimeter on it yet, is there a fuse for the charging system? The batteries are all in good shape, i tested them all.
  3. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Alt is shot. You check voltage at alt with motor off and then running , or take hot wire off and check voltage.
    Carry a spare.
  4. hkerekes
    10
    Jun 12, 2010
    If the truck wasnt under warranty i would have a spare, and wouldnt be waiting on the dealer. It only has 77,000 miles on it unfortunately but i do have 5 year 500,000 on the truck. One other time when i had to jump it off when it sat for two weeks the alternator wasnt charging but a power cycle fixed the issue and it never came back again.
  5. 062
    062 Road Train Member
    6,351
    34,023
    Oct 20, 2013
    I don’t know if the alternator has a external sense wire(doubt it does) but if the sense wire breaks you’ll have no/ low output.
    @Goodysnap
    Goodysnap Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,784
    9,223
    Jul 12, 2017
    As long as you have good battery voltage at the alternator hot post and the belts good. no output = bad alternator.
    062 Thanks this.
