tach and cruise control not working help
Discussion in 'Freightliner Forum' started by ptwn1, Oct 4, 2012.
  1. ptwn1
    ptwn1 Light Load Member
    94
    11
    Oct 4, 2012
    hello my tach and cruise control is not working tach is stuck at 2200 rpm and how do you remove the tach
  3. ptwn1
    94
    11
    Oct 4, 2012
    sorry i have a 2002 freightliner century my cruise control dosent work either i think it has something to do with my tach not working. This is my first truck and im waiting for all the paper work to go through. Im thinking of replacing the tach with a new one i hope that will fix the cruise control too.
  4. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    Maybe the pickup sensor has vibrated loose. The ones I've seen use a locknut to hold it once the depth is set. You loosen the locknut, then screw in the sensor by hand till it contacts the teeth it is sensing, then unscrew it a fraction of a turn (not sure what yours would be) and then tighten the lock nut to hold that setting. Also, check the wiring at the sensor as this is a more common place to break.
  5. ptwn1
    94
    11
    Oct 4, 2012
    Ty for the reply do you think that is the reason why the cruise control is not working?
  6. Grumppy
    3,234
    11,402
    Dec 11, 2010
    West Monroe, La
    Just asking... so, you know for sure that they both stopped working at the same time?
  7. ptwn1
    94
    11
    Oct 4, 2012
    I just bought the truck and i want to try to fix it myself. I just paid the guy today i also gotta fix the cigarrette lighter thing i need it for my gps and stuff
  8. ptwn1
    94
    11
    Oct 4, 2012
    The cigarette plug thing i looked for the fuse in the passenger side dash and the fuse is still good. I think i gotta find where the wire goes. Is there another fuse box that i dont know about?
