Tach is wrong
Discussion in 'Kenworth Forum' started by drewfarmsllc, Feb 7, 2023.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    83
    32
    Oct 18, 2008
    South Carolina
    I plugged my blue ink tec eld into my data port on my 2020 KW t680 and now my tach is off by 4 to 500 rpms on the dash. The digital gauge is correct and the eld is correct. Anyone have a suggestion on how to correct this? I have switched the truck off with the Bluetooth in and with it disconnected but it's still the same
  3. W923
    W923 Road Train Member
    1,398
    4,282
    Feb 28, 2022
    Buy an older truck…preferably old enough to get rid of the eld. You say the tach is off but that the eld and the digital gauge are correct so how are you verifying that it’s wrong? I guess maybe I am missing something.
  4. drewfarmsllc
    83
    32
    Oct 18, 2008
    South Carolina
    Sorry I didn't make it clear. The tach guage on dash shows 1100 rpms at idle but if you use the digital option it shows 600. I have a Pete 379 and decided to go this route because of back problems. If you have ever ride in my 680 you will understand. Best riding and most comfortable truck I have ridden in. Thanks for your comment and sorry I didn't make it clear. Be safe out there.
  5. W923
    1,398
    4,282
    Feb 28, 2022
    So what happens as you bring up the rpm, do they come back together or stay roughly 500 apart?
    My guess is your going to need someone with a computer to fix or figure out the problem.
  6. drewfarmsllc
    83
    32
    Oct 18, 2008
    South Carolina
    Had to change batteries. After the change the rpm gauge is correct again
    W923 Thanks this.
  7. W923
    1,398
    4,282
    Feb 28, 2022
    Interesting
    Probably a poor connection issue on one of the smaller wires in the battery box if I was guessing.
    flood and Concorde Thank this.
