Tail lights, dash, and clearance lights out ??
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, May 3, 2018.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Good morning. Need some help with this one . I have a 1994 Peterbilt 378 dump truck . I noticed my tail lights, dash lights and clearance lights not working . My head lights, signal as brake lights work . Checked the small 15 am fuse for the dash lights looks good. Anything else I can check ? Thank you
  3. Feedman
    Feedman Medium Load Member
    418
    6,423
    Aug 17, 2015
    West mi
    Find the relay in the panel and swap it for a different one. When they get old they get hot faster. Will it might work at first it doesn't take long to go out. Had a kw that did the same thing one night. Figured out if I dimmed the dash down it was enough to keep going.
    Nestor and Diesel Dave Thank this.
  4. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    If all 3 are dead and your marker, tail and dash fuses are all good and the relay is good I would check the toggle switch for power & continuity next; if that checks out you are hunting for a broken wire. If it was a short the fuse/fuses would have blown.
  5. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    If the fuses are good Its probably the marker relay. Dash lights are fed from the marker circuit 8.
    Nestor Thanks this.
  6. Diesel Dave
    9,701
    33,080
    Jan 20, 2010
    Hesperia, Ca.
    I had all 3 issues on my 94. Switch the relays, toggle switches, and there a circuit breaker at the bottom on the fuse box, there white little buttons. My issues where all different times. But I bet it’s the relay.
    Nestor Thanks this.
  7. Nestor
    160
    23
    Oct 21, 2015
    Thanks guys ! It was circuit breaker . Button looking fuse popped out pushed it back in and all good!!@
    RET423 and Diesel Dave Thank this.
