Tail lights on but not working...??
Discussion in 'Ask An Owner Operator' started by Batman13, Aug 8, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    I have a 14 freightliner cascadia..and my tail lights work somewhat..signals, hazards, brakes..except my reverse light isn't working..and the problem with the 2 others lights is that they are on..but they are super super dim..to the point you cant even hardly see em at night!! Anyone have any ideas??
  3. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Broken wire and they r touching, start running the wire and find it
    86scotty Thanks this.
  4. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    Dim lights are often caused by a bad ground.
    Cattleman84, m16ty, 86scotty and 4 others Thank this.
  5. Batman13
    110
    45
    May 20, 2020
    So I got my left light bright..and the reverse..but now the turn signal isn't working..right is still dim but signal working..
  6. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Try to ground your lights directly to the frame.
    With lights, a bad ground can make your lights go crazy and do things you could never imagine.
    feldsforever Thanks this.
  7. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    When you figure it out. Please post it so I Can gain some knowelage.
    Thanks
    Speed_Drums Thanks this.
  8. AModelCat
    164,764
    Sounds like either a power supply problem or a ground issue. Since the grounds typically go to the frame, they tend to rot after a while.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,015
    71,497
    Nov 1, 2017
    The Sticks, Idaho
