Tandems position for backing
Discussion in 'Questions From New Drivers' started by TuckerT, Jan 30, 2026.
  1. TuckerT
    TuckerT Bobtail Member
    Jan 30, 2026
    When you are backing into fairly tight dock in between two other trucks on either side, do you find it easier to do so with tandems slid all the way back (trailer less responsive to turning), slid all the way up (trailer very responsive, tail swing risk), or tandems set in the middle? In my scenario you are required to perform 90 degree alley dock type maneuver and yes there is enough room for the tandems slid all the way back. Im fairly new without a lot of experience backing in this situation. I literally just completed a back like this but it was not pretty and I kept other drivers waiting too long. Thanks for the feedback.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    A little easier backing with them back,if you have the room in front of the docks.
  4. TuckerT
    Jan 30, 2026
    Mine were all the way back but I kept overshooting on the opposite side, having to keep readjusting and try again. I was also a little nervous because others were watching and having to wait on me.
    dosgatos Thanks this.
  5. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    I agree with @North Pole Nightmare . If I have room to swing my truck, I'll slide my axles all the way back.
  6. MACK E-6
    49,993
    237,958
    Best to avoid tail swing if at all possible IMHO. You can’t see what you’re about to hit.
  7. firemedic2816
    firemedic2816 Road Train Member
    1,144
    1,631
    May 14, 2016
    Walton Kentucky
    F’em they should have started their day sooner LET THEM WAIT, don’t hit nothing and don’t worry about everyone else waiting, it will get easier with practice
    As far as position it depends on the room in front
    Practice Practice Practice
  8. Brandt
    Brandt Road Train Member
    4,624
    6,358
    Sep 17, 2012
    I was told slide tandems back if it a tight hole for two reasons. If between two trucks your trailer swing can easily hit other truck. It doesn’t really take more room to back trailer if tandems are all the way back. So if you can’t get trailer in dock with tandems all the way back then it’s also your early warning theirs not enough room.
    Before 53’ trailers we did not have a lot of tail swing to worry about with 48’ trailer. All the old dock were not designed with 53’ trailers in mind. So some can be to tight. That’s why I was told slide tandems back all the way if tight dock or parking spot. If you can’t get into the spot then you never probably will and the trailer swing would have probably hit the other truck. Also there could be something in front of dock you tractor will hit.
  9. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Well, horse a piece. When I did multi stop, I had the tandems all the way forward to get around, I wasn't about to slide the tandems at every stop. I just got used to how the trailer backed in all the way up. I didn't worry about trailer swing, I made sure I was always clear. All the way back , is a lot less responsive, requiring several "pull forwards", and many times a lower dock, they will have you slide the tandems back anyway. On many loads, I knew where 34K was and I didn't mess with the tandems all that much. Slow and easy, and GOAL, is the best advice, some trailers, like RR chassis or tankers don't have sliders.
    TuckerT Thanks this.
  10. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,548
    2,702
    Jan 7, 2023
    Occasionally, when I got one of those "nightmare docks", I would leave the tandem pins open. Slide forward to get around the corner of the building, then slide them back to get into the dock so that the tail wasn't 3' above the plate. Sure beats getting out halfway through to open the pins, especially when you need to repeat the process in reverse when leaving.
    Big Road Skateboard, lual and TuckerT Thank this.
  11. lual
    lual Road Train Member
    5,316
    9,693
    Oct 22, 2020
    SW Georgia
    Excellent thread, Gentlemen.....:notworthy:
    :occasion5:
    -- L
