1. Attention employers: We now require a valid DOT# for anyone wishing to post a driving position. If your job offer doesn't contain a DOT number, it will not get past moderation and will not appear in the forum. The other requirements in the sticky at the top of this section are still required as well. Thank you for understanding.
Tanker & Hazmat driver (no touch freight)?
Discussion in 'Seek Employment' started by Bonita Nut, Aug 28, 2023.
Thread Status:
Not open for further replies.
  1. Bonita Nut
    Bonita Nut Light Load Member
    169
    92
    Aug 21, 2023
    Tanker and Hazmat drivers?
    Tanker and Hazmat driving jobs that are
    no touch freight that you would recommend in Georgia?
    I hope I asked correctly? :)
    Thank you.
  3. kemosabi49
    10,992
    47,978
    Jan 13, 2013
    SW Arkansas
    Chemical tankers are rarely no touch all of the time unless you happen to get on something dedicated. Though on the loading end it usually is. On delivery at chemical plants it is usually no touch too. At other places you may have to hook up hoses and open the valves. Wherein Georgia?
    Bonita Nut Thanks this.
  4. Bonita Nut
    169
    92
    Aug 21, 2023
    Middle - Southwest Georgia
  5. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    Action Resources (chemical) and Indian River (food grade) both have terminals in Cordele.
    I'm not sure if they are still in business or not, but Williams Dairy Trucking used to be in that area.
    @lual would be of great assistance with this if you listen to him.
  6. Bonita Nut
    169
    92
    Aug 21, 2023
    Thank you so much.
    @lual I would greatly appreciate your help and guidance. :)
  7. lual
    lual Road Train Member
    5,389
    9,839
    Oct 22, 2020
    SW Georgia
    I will assume from all the above that by "no touch".....you mean basically that the driver is not involved with the loading or unloading process for the tank's contents.
    Your best bets for that (in Georgia) would likely be Indian River's newer terminal, in Cordele, GA (for you out-of-state readers, that's pronounced, "Kor-deel"...here in GA)....or you could contact Early Trucking Company ("ETC" on their trucks)....based in Arlington, GA:
    Early Trucking Company - EMPLOYMENT
    Both of those will be hauling food-grade (non-hazmat) food products.
    The vast majority of loads with Indian River will be driver non-assisted.
    I don't think either of the above suggestions will get you a "home daily" driving job, however. Maybe home weekly.
    Again -- best to inquire within.
    Not so sure about the same with ETC -- inquire within.
    ETC will very likely be mostly dairy loads.
    -- L
    88 Alpha and Bonita Nut Thank this.
  8. Bonita Nut
    169
    92
    Aug 21, 2023
    Thank you for your reply!
    Yes, no touch meaning basically that the driver is not involved with the loading or unloading process for the tank's contents.
    I would prefer local (home daily), but I will definitely check them out now. :)
    Thank you so much.
  • Thread Status:
