Tanks not equalizing
Discussion in 'Freightliner Forum' started by The Deplorable, Jun 21, 2020.
  1. The Deplorable
    The Deplorable Bobtail Member
    Jan 20, 2020
    I have a 2015 freightliner cascadia with 150 gal on left side and 120 on right. Here recently the tanks have not been equalizing. The right side is about half to 3/4 full when the left is reading empty. Any help on where to start trouble shooting would greatly be appreciated. Thank you
  3. bad-luck
    bad-luck Road Train Member
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    Had the same problem. It was the tank vent. You need to replace the vent on the tank that has the 1/2 to 3/4. Its located on top of the tank. May or may not have a short hose that runs down the back of the tank
  4. Walshy
    Walshy Bobtail Member
    9
    5
    Jun 10, 2020
    Queensland Australia
    Definitely sounds like a tank breather issue
    Rideandrepair and The Deplorable Thank this.
  5. 25(2)+2
    18,759
    45,985
    Sep 18, 2006
    the road less travelled
    Check and make sure the Equiflow system hasn't been removed from either tank. I drove one like that where it was removed and replaced with a street el, and that one did the same thing. The tank with the gauge had a much lower level than the other one. I only ran it a bit over a month, and was always worried it would run out on me. It never did, though.
  6. The Deplorable
    Jan 20, 2020
    Alright guys I took off the valves and checked them and they were both plugged up. I put two new ones on with new hoses so hopefully that will fix the problem.. Thanks everyone
    Rideandrepair Thanks this.
  7. bad-luck
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    I think you found the problem! And they little vent wasn't cheap either was it?
    The Deplorable Thanks this.
  8. The Deplorable
    Jan 20, 2020
    Well so far so good. Parts were cheap I paid about 15 bucks for two. Thanks .
    uncleal13 Thanks this.
  9. bad-luck
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    Glad to here!!
