Tapping sound from air filter
Discussion in 'Volvo Forum' started by Lomex, Mar 28, 2016.
  1. Lomex
    Lomex Bobtail Member
    5
    New Jersey
    Hi guys , I have a Volvo 780 d12 engine , a while ago I start hearing tapping sound from air filter and I've been told that it's from air compressor cause I put a new one , and after 20000 miles the sound is much louder and the turbo start giving a sound like whistling a lot , ...
    Any idea , thank u
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Open it back up and let the squirrel OUT!
    tucker, Straight Stacks and Lomex Thank this.
  4. Lomex
    5
    New Jersey
    Can u pls tell me what that means ,..
    Thank u
  5. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    I'm suspecting a camshaft lobe failure is coming.
    Standing beside the engine with the hood open,Check when you turn off the engine if the tapping sound follow the engine rpm decreasing ?
    Ben
    Lomex Thanks this.
  6. Lomex
    5
    New Jersey
    Thank u Ben I'll definitely check this tommorow , btw the truck has a lot of power ,and when is in neutral it works perfectly ,.. Allready check a few mechanics, no one has any idea what it is
    Thank u so much
  7. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Truck sending you morse code:
    Get Steering Shaft Fixed.
    Slowpoke KW, tucker and Lomex Thank this.
  8. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    If your tapping noise is involving injection system of your engine the noise will be eliminate when you turn the engine Off from idle.
    I'm guessing the noise will follow the engine Rpm. . .(camshaft lobe)
    Let me know the result please.
    Ben
    Lomex Thanks this.
  9. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    There is another possibility if your tapping noise is there only under engine load i remember many years ago there was a Volvo bulletin to add a special baffle inside the turbo on the intake side close to the turbo compressor wheel, that special baffle is hold in place by a big snap ring.
    The purpose of the baffle is to eliminate the turbo pulses (can generate drumming in the air filter housing)
    Did you replace the turbo recently ?
    Ben
  10. Lomex
    5
    New Jersey
  11. Lomex
    5
    New Jersey
    The turbo is changed 50000 miles ago I bought it like that , the truck is 2007 , there is an engine break attached to the turbo,planning to try one more mechanic shop to c what they will tell me,I hope I'll fix this problem soon and tell what was the issue .. Thank u Ben
