Tarp rack
Discussion in 'Flatbed Trucking Forum' started by HalpinUout, Aug 26, 2017.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    Anyone know of a place that sells/makes a rack of some sort to go on top where my ladder is so I can secure a couple tarps up top? Ive seen some with "rack" type deals and also seen some that almost look like a giant dish on top that holds them...either would be fine... 20170826_190017.jpg
    Logan76 and 4mer trucker Thank this.
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Any tinbender or blacksmith could bend you one.
    Logan76, Orangees, noluck and 2 others Thank this.
  4. motocross25
    motocross25 Road Train Member
    3,890
    11,960
    Sep 23, 2010
    Overland Park, KS
    That's a bada$$ tool box
    Lepton1, Puppage and HalpinUout Thank this.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Lifting tarps over you head... Watch how fast that gets old. :yes2557:
    Can you put the chains in one "door" and tarps in the others? Might need to fold them up so they fit the dimensions available but it will help alot and keep them dry.
    I use a setup with a tarp rack on top and it doesn't take much, one awkward step, and you can blow a gasket.
    VTech, Lepton1, noluck and 3 others Thank this.
  6. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    I was going to put the lumber tarps I don't use often on top... Have chains/binders in 2 doors and a steel tarp and straps in another...
    skellr Thanks this.
  7. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    See george at mercer store he has them in stock
    HalpinUout Thanks this.
  8. Razororange
    Razororange Road Train Member
    2,722
    25,884
    Dec 20, 2011
    Milwaukee, WI
    3/16 piece of flat or diamond plate aluminum. Cut to length you need for your tarps. Figure out how wide and add 4-6". Take that extra 4-6" and bend it straight up 90° and put that side 3" from the back of your sleeper on top. Bolt or weld it in place once it's up there. Find a local Fab shop and I bet you can get it done for less than $100+ materials.
    cke, Logan76, noluck and 2 others Thank this.
  9. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    Have you verified you can lift a lumber tarp up there? I would bet most can't lift a lumber tarp over their heads.
    Just something to think about.
    If you do go that route make sure you use a 1" ratchet strap or similar to secure the tarps. A bungee will get you a ticket.
    cke, Lepton1, noluck and 3 others Thank this.
  10. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Hmmm, never knew that... Will do.
    cke Thanks this.
  11. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    So are you insinuating I'm weak? Haha. But yes I can lift it. And ya I have the ladder secured with a ratchet strap so I am familiar with that regulation.
    cke and Logan76 Thank this.
