Tax plan
Discussion in 'Trucker Taxes and Truck Financing' started by cat smoke, Dec 16, 2017.
  1. cat smoke
    cat smoke Light Load Member
    130
    124
    May 30, 2016
    I keep seeing pass-through income that one can do without paying a bunch of taxes? I'm trying to make sense of the new tax plan, but I am unsure. I am currently a sole proprietor. Should I form a LLC to get the tax break if that is what it really is?
    Oldironfan Thanks this.
  2. Derailed
    Derailed Road Train Member
    1,824
    1,543
    Dec 10, 2008
    Ballston Lake NY
    An S corp is what gives you the pass through, however if this new tax plan goes through I am wondering if one would be better off with a regular C corp being it will bring a lower tax rate for corporations
  3. Rickp
    Rickp Medium Load Member
    360
    373
    Apr 14, 2016
    Llc is taxed as a pass through
    laaylor Thanks this.
  4. Scooter Jones
    Scooter Jones Road Train Member
    5,484
    8,430
    Apr 19, 2011
    PNW
    I have an LLC filing as an S Corp classification. One of the benefits of classifying yourself as an employee of the S Corp is being able to take a dividend out of the S Corp with is taxed (in my case) at a 15% rate. That is considerably less if I were to run that same amount through as a schedule C sole proprietor.
    There are obviously red flags if one takes an inordinate amount out as a dividend. When I did my research the ratio should be around 75% W-2 wage and 25% dividend.
    Being able to get the S Corp classification from the IRS is not a given either. There are a few hoops you have to jump through, which I would recommend a competent CPA help you with.
  5. BrandonCPA
    BrandonCPA Bobtail Member
    20
    20
    Dec 16, 2017
    @cat smoke You will want to do an LLC and have it taxed as an S corporation. There isn't a dividend like Scotter is suggesting. There are distributions, which are tax free relative to the amount of basis you have in your stock. With the 2018 tax changes and LLC will be more advantages due to new deduction for flow through income that will be taken on the personal tax return.
    blairandgretchen and cat smoke Thank this.
  6. Oldironfan
    Oldironfan Road Train Member
    3,799
    3,218
    May 22, 2017
    Watching this post closely.
  7. Scooter Jones
    5,484
    8,430
    Apr 19, 2011
    PNW
    My bad, I MEANT to say distributions, not dividends.
    blairandgretchen Thanks this.
  8. Crisvalencia90
    Crisvalencia90 Bobtail Member
    12
    Feb 16, 2017
    Does anyone recommend ATBS to do their taxes?
    Or can I get good suggestions on an excellent trucking CPA to do taxes for my first year filing?
  • Draft saved Draft deleted
