The TCS sensor and ABS sensor are turned on and it is making the truck turn off after it drives for about 45 minutes. Anyone know what could be the problem?? Thank you!
TCS and ABS sensor on VOLVO vnl 670
Discussion in 'Volvo Forum' started by Grimany, Oct 8, 2017.
Need a bit more information. Year engine auto or 10speed.
Did you see what code it's throwing? -
The code will give you an idea where to begin.
Drives ABS sensor or wiring. If you have DLA you can download good test program from Bendix. AComDiagnostic.
When last time did you check drive hub bearings? I'll bet never. If play is to much it can cause ABS sensor misreading. -
Volvo.2013 and Snailexpress Thank this.
Did you ever fix the issue? If so what was it?
