Tear in red line hose
Discussion in 'Questions From New Drivers' started by dboot01, Jan 28, 2022.
  1. dboot01
    dboot01 Light Load Member
    135
    225
    Nov 8, 2021
    Leaking massive air. Will duct tape do the trick? Or is that dot violation? Thx
  3. InTooDeep
    4,981
    37,365
    Jan 17, 2016
    Carmichael CA
    It is a violation for sure. No duct tape won't hold it.
    dboot01 Thanks this.
  4. Hawkeye72
    Hawkeye72 Light Load Member
    274
    836
    Feb 20, 2015
    Iowa
    Replace it! Duck tape isnt going to hold that kind of pressure.
  5. mitrucker
    mitrucker Road Train Member
    5,520
    10,473
    Dec 15, 2010
    Lapeer, MI
    Duct tape? There are no other options except replacing that hose.
  6. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    You should have a spare air line in the truck always, when co pays for 2 air lines and one is put on keep the other line in side box, a adj, wrench or vice grip will let you be able to change one.
    fishonron and Diesel Dave Thank this.
  7. BlueDuck1883
    BlueDuck1883 Light Load Member
    63
    18,726
    Jan 28, 2022
    Shady Point, Ok
    Posted November 8th. I'm curious to know if @dboot01 tried to wrap it with duct tape.
  8. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    I hate this kind of questions. It should be specifically detailed.
    Are you at the truck stop, or in the middle of nowhere? Can you drop your trailer and bobtail to the shop? Do you have tools to replace the hose? And so on..
    PS: If you have the tools and stuck nowhere, replace hoses blue to red and red to blue side. Duct tape the red (now blue) with a lot of it (electrical works better) and get to the nearest shop to buy lines, both of them, since they are old and fragile. Do not speed and keep an eye on pressure when you break. Blue line is a return, so it does not hold the air bags and breaks under constant pressure AFAIK.
    D.Tibbitt and BlueDuck1883 Thank this.
  9. BlueDuck1883
    63
    18,726
    Jan 28, 2022
    Shady Point, Ok
    A little bit of common sense and knowledge of the truck you in, goes a long ways.
    goga Thanks this.
  10. Big Road Skateboard
    7,526
    43,163
    May 2, 2021
    Definitely a bubble gum repair
    BlueDuck1883 Thanks this.
  11. BlueDuck1883
    63
    18,726
    Jan 28, 2022
    Shady Point, Ok
    Duct tape only works on Fords, right?
