Technical Help - Please and thank you
Discussion in 'Ask An Owner Operator' started by Kat_Dawn, Jun 27, 2020.
  1. Kat_Dawn
    Kat_Dawn Bobtail Member
    4
    6
    Jun 27, 2020
    I have a 2019 KW t680, all the lights on my trailer work but I have no clearance lights. Brake lights, turn signals etc.. still work... but the clearance lights don't... does anyone know where the #### fuse is located for it. I cant find it
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Had a similar issue. Check the electrical cord where it plugs into the trailer. Wiggle it and see if you clearance lights come on. If they do you need a new socket on your trailer. This is very common when the socket wears out. Can use a bungie or folded up paper as a temporary fix
  4. Kat_Dawn
    4
    6
    Jun 27, 2020
    its been on 4 trailers now. that's why I think its the fuse... I look under the bunk and on the drivers side under the ignition but I don't see a clearance/marker light fuse on the panel anywhere
  5. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Ok, check the end of the electrical cord that plugs into the truck, do the same thing there. I am not sure where the box is on a kw i have a pete. Maybe a relay.
  6. Kat_Dawn
    4
    6
    Jun 27, 2020
    ill check, I just have to trace it. thank you. will report back
  7. Kat_Dawn
    4
    6
    Jun 27, 2020
    good news, found the fuse. it was blown. replaced it and it works now
  8. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Great!! Glad you fixed it
  9. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome
  10. Ridgeline
    22,725
    123,401
  11. NCCU_EAGLES
    NCCU_EAGLES Bobtail Member
    23
    4
    Sep 5, 2011
    Charlotte, NC
    I have same truck with same issue... where is the fuse? As stated none of the fuses under the steering column appear to be for clearance lights. Neither are the fuses under the bunk. Where is it? I've already replaced the power cable twice.
    Old Man Thanks this.
