I have a 2002 international 9400i the fan never work automatically as it should like any truck out there, I bought this truck last year, and this fan issue it been on it ever since, can any one tell me where I can find the temperature clutch fan sensor.
I greatly appreciate
Temperature fun clutch sensor
Discussion in 'Ask An Owner Operator' started by Thouray, Sep 15, 2022.
There isn’t one, it is controlled through the ECM.
I checked the solenoid the one on the fire wall and it was working properly, And I checked the wiring that it connects to it they are all conditionally good. Is there is any other way that I need to be checking so I get to the bottom of it?
Are you sure your gauge is correct? Fan should engage at roughly 212*. What engine?
Yes, take it to a shop or better yet a dealer and have them do a full ecm dump and look at the settings for the fan.
Yes I am sure
yes I believe it’s correct because the temp goes up to 215 and the fan never engages. It’s Cummins N14 -
You really need to verify gauge accuracy first. Best place to start is hooking up a scan tool to see what temp the sensor is showing the ECMAModelCat Thanks this.
Will do that, thanks for the tip, greatly appreciate it
