The best cheap Redneck APU?
Discussion in 'Ask An Owner Operator' started by c.w, Feb 1, 2022.
  1. c.w
    c.w Light Load Member
    108
    49
    Jun 26, 2021
    Hello
    After some research,I found this portable generator
    RYOBI RYI2322E
    with remote start and shutdown.
    https://www.homedepot.com/p/RYOBI-O...ickid=TdPTBQUV-xyIU6LXgwxrqU8ZUkGy-w0YQ1F2XM0
    So,the next is to get an AC. some one use 5000BTU portable AC plus window exhaust pipe
    kit. but also some people put a window AC under the bed and lets the hot air blow out from a opened cabin storage door.
    Is 5000 btu enough during the summer?
    What kind of AC is the best for this generator?Waiting for your comment,thanks!
  3. Dave_in_AZ
    445,338
    TriPac Evolution
    Evil_E, mjd4277, Vampire and 2 others Thank this.
  4. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,060
    2,289
    Dec 15, 2021
    I have one for my RV.Its nice,you can monitor it on your phone,check fuel and shut off if needed.I don't know if it will run an AC unit or not.It runs wide open when I make a pot of coffee.
    It runs very quiet.
    c.w Thanks this.
  5. Big Road Skateboard
    7,674
    44,365
    May 2, 2021
    That's not much of a generator to run an A/C. Think you'd need to step it up. My 2k Honda will not run the small unit on my pop up camper
    86scotty, Bean Jr. and c.w Thank this.
  6. abyliks
    abyliks Road Train Member
    4,261
    10,182
    May 2, 2010
    ludlow MA
    2000 watt harbor freight and a 10k portable btu ac is what I have, cools the bunk but needs the curtain closed and this way I just have to put the hose out the window
    I don’t think 5k would do it unless you have a small flat top
    c.w and ProfessionalNoticer Thank this.
  7. Red Clay
    Red Clay Bobtail Member
    7
    7
    Aug 17, 2012
    I also use a 2k watt inverter generator from Harbor Freight. You can buy a tandem kit that allows you to combine two of them together for double the output.
  8. abyliks
    4,261
    10,182
    May 2, 2010
    ludlow MA
    might as well just go with the bigger generator and have one less engine to worry about IMO
    86scotty Thanks this.
  9. Red Clay
    7
    7
    Aug 17, 2012
    I use two for easier movement/carrying although many people wouldnt need to move it very often.
  10. flood
    flood Road Train Member
    4,170
    4,053
    Dec 25, 2010
    for $100 more you can get this predator 3,500 (it's what I use)... quite as a Honda.. can run a ac. (It'll run my 5,500 btu ac for 11ihs hrs on 2 gl) I added a remote start kit... add the 2 year warrenty (FREE replacement for any reason) just walk on the store "hay it doesn't start" and 15min later walk out with a new one on the box....!
    3500 Watt Super Quiet Inverter Generator
    You'll want a 5,500 btu or BIGGER portable ac
    c.w, 86scotty and shooter19802003 Thank this.
  11. 86scotty
    86scotty Road Train Member
    4,844
    13,410
    Aug 27, 2017
    Appalachia
    OP, you need more generator if you're going to do this. That one is too expensive for it's size anyway. Lots of people have had great luck with the Predator 3500.
    Plus, what self respecting redneck doesn't get his gear from Harbor Freight?
