I was doing a search for some stuff and found this:
Anyone use the Conestoga? How hard are they to set up? What are their limitations?
The Conestoga
Discussion in 'Ask An Owner Operator' started by Working Class Patriot, Feb 28, 2008.
Heh, guess this was something people know little about or choose not to talk about
Tarp systems are the way t go if you ask me. They will limit what you haul since you can't do over width or anything very tall. I don't know about that perticular brand it's not one I have seen before
We chose not to go with one, instead buying a flat w/sidekit because you can haul OL, OD and most loads for flats arent very tall unless you haul hay. I think we have had 2 loads above the cab of a Peterbilt, the rest 2-4 ft hi. Rolls of Aluminum on end are the tallest stuff, that and LD33 containers. I don't think its worth the extra fuel.
Yeah that set up looks like it would be a tarp saver (the Conestoga) but someone in another thread mentioned loading by cranes would be difficult.
I haven't pulled one. There is a company in Rochester, MN that makes cabs for ag and industrial equipment, and they used those or something similar, its much easier to secure cargo on a flatbed.
I have also seen some with swinging doors on the back, those work much like a dry van.
The alternative in using a regular box is that you need to secure the article in a rack to protect it. In certain applications, the roll tarp is a good choice, but not in all applications. -
no, you could load that with a crane. What you can't load with a crane is a curtain side van. They have a metal roof and swing doors with curtains on the side. They can only be loaded from the side or rear.
I found these on Aero Tarps
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.aeroindustries.com%2Fphoto%2Fconestoga2%2Fimg0014-med.jpg&hash=2079012b3be2eb185f7a14fb17967904)
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.aeroindustries.com%2Fphoto%2Fconestoga2%2Fdropdeck-med.jpg&hash=404857cb77e262d6f3876bb81548ab63)
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.aeroindustries.com%2Fphoto%2Fconestoga2%2Fcoilsoverhead-med.jpg&hash=56d8580ba95d0e4fa93bece03cea4498)
Not bad but I they must be expensive at first. -
I believe Chameleon and Quick draw are the brands I have seen allot of. Not sure.
I bet they aint giving them away
they add between 15 and 20 k to the price of a new trailer
if your rail gets bumped it makes it extremly difficult to open and close
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.highwaystar.ca%2F0209gear1.jpg&hash=4aadb35c7ff2295831a9c055c901cf5a)
