The Pneumatic Tanker Thread
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Air Cooled, Sep 6, 2016.
  1. Air Cooled
    Air Cooled Road Train Member
    1,314
    1,095
    Jul 17, 2011
    Baltimore
    I would like to know if we could start a Pneumatic thread at the approval of the administrator. This could be the spot for sharing loading/unloading tips and stories, pictures, and questions from experienced haulers and those new or looking to get into this area of trucking.
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,420
    8,016
    Jul 11, 2012
    in the bush somewhere
    Nooo!!!! Shhhh!!!! We don't want our secrets to get out!!!!!
    Seriously though, the reefer folks have one, the flatbedders have one, car haulers, so why not?
    Northern Nomad Thanks this.
  4. Air Cooled
    1,314
    1,095
    Jul 17, 2011
    Baltimore
    Thank you! I guess I'll start with a question. What do you folks set your RPMs at when your blowing into a Silo 100-200 feet in the air or into a Guppy and why? I was running 950 RPMs into a Silo and 850 into a Guppy. I felt that it may have been too much air so I've cut back 100 RPMs on both. Seems a little smoother but not much faster than before. Thoughts on this? I'm still new to this.
  5. RockinChair
    RockinChair Road Train Member
    5,575
    15,705
    Feb 19, 2012
    Corpus Christi, TX
    What product are you unloading, and what are your tank and line pressure gauges reading?
    What ratio PTO do you have? I assume the blower should have a rated operating speed/range.
    Also, what's a Guppy?
  6. rbrtwbstr
    3,420
    8,016
    Jul 11, 2012
    As Rockin Chair said, your blower speed will depend on what ratio your Pto is, and what kind of blower you have. Some of our trucks run a Tuthill blower, others run the Gardner Denver, but all run the same ratio Pto. The Tuthill needs to turn faster, so with Lime, those run at 1200 engine runs. The Gardner Denver we run at 900 for lime.
    With my setup, which is the GD blower, I run 900 for lime, and about 850 for cement, no matter the height of the silo. If going into a pig with cement, I run 800. I keep my pressures at 14-16 psi. Usually, if the baghouse is clean, I unload 26.5 tons of cement in 40-45 minutes in a silo. In a pig, about 30 minutes. Lime is usually 45 minutes to an hour, depending on conditions. The hotter the lime is, the slower it comes off, generally speaking. And most places we take lime to have some really screwed up piping systems. (40-60 ft vertical, through a 90 degree, then horizontal for 100ft, then a 90 up another 40 ft into silo is our worst)
    But unlike some others, I do not stand there unloading with a stopwatch in hand. I get it going and hop in the truck and doodle on here, or do paperwork.
    LoneCowboy and RockinChair Thank this.
  7. RockinChair
    5,575
    15,705
    Feb 19, 2012
    Corpus Christi, TX
    Lemme guess...paper mill?
  8. rbrtwbstr
    3,420
    8,016
    Jul 11, 2012
    Nope. Co-gen power plants. I'm actually at the very one I was speaking of....:mad:
  9. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Great idea for a thread!
    I haul frac sand. With a Chelsea PTO and a Tuthill 1050 blower. I unload at 1300 rpm, with my 13 speed trans. The trucks with 10 speeds run 1200 rpm. Can unload 50,000 pounds of 20/40 in about 25 minutes with 20 feet of hose.
  10. rbrtwbstr
    3,420
    8,016
    Jul 11, 2012
    There's actually frac sand to haul??? LOL Our sand guys have not hauled sand in well over a year. Rumor is it's going to start up again around here in the next couple months. I did the gas well thing for a bit, wasn't my cup of tea. But the money was insane at the time. Honestly though, at the end of the year, I do better working local. 3 loads a night, usually home by 10am, very little waiting around to unload. Most nights I don't see more than three people, if any..
    On another note, those Tuthill blowers seem to work really well in sand, not so much in cement.
    ShooterK2 Thanks this.
  11. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    10-4. Yeah, the sand has its ups and downs. We have managed to stay alive with it, but the small company I'm leased to has a direct contract with a frac company. They've used us exclusively for about 12 years now. We bend over backwards to keep them happy, and they treat us good. Rates are down from a couple years ago though.
    Sounds like you've got the gravy train on your local gig.
