The Real Skinny.
Discussion in 'Freightliner Forum' started by fr8wurx, Mar 8, 2013.
  1. fr8wurx
    fr8wurx Light Load Member
    128
    84
    Jan 27, 2013
    Lingle, WY
    I have an 01 Century with a Detroit S60. The Breather tube when at a stop looks like a couple old guys smokin on a bunch of Cubans. My mechanic says that it is blow by on the rings and that I need an in-frame overhaul done. But I have also read that blow by and smoke coming out of the breather is relatively normal on the Detroits. I barely use any oil in the crank case. I use more in the power steering than the engine. Luckily I am slowing down the power steering leak. Just a couple more hoses to check out and possibly replace. So, in short, is it bad and I need to get it fixed immediately? Or is it normal and just watch my oil consumption. Thank you in advance for your advise.
  3. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Whens the last time you had an oil change with a quality oil
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    detroit shop do a splatter test on the blow by tube it appears some splatter is ok.
  5. nv1
    nv1 Bobtail Member
    16
    Mar 8, 2013
    Reno, NV
    I have 2001 century with s60 has had same smoke for the 7 yrs I've had it. Detroit dealer @ home says s60 do that.
  6. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Smoke out of the blow-by tube is relatively common on older series 60's. They do that. If you're not using oil, you certainly don't need an inframe yet - however as the miles go up on any engine your chances of having something major break also go up. You migh want to start doing oil analysis from a quality lab (not one of the benchtop deals at the oil-change emporium) to keep an eye on wear metals. A jump in those results can give you some warning of a major event inside the engine before it catches you in a bad spot in BFE.
    My bet is that the mechanic's money is lacking this month, and he needs some business.
  7. fr8wurx
    128
    84
    Jan 27, 2013
    Lingle, WY
    I change my oil every 15k and use only Rotela.
  8. losttrucker
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    The 2 times Ive used Rotela in my S60, ive had that along with the "burnt" smell
  9. nv1
    nv1 Bobtail Member
    16
    Mar 8, 2013
    Reno, NV
    I generally use Delvac which is what detroit recomends for S60. I agree with ironpony any owner should be doing oil analysis @ least every other oil change under normal change cycles (12-15,000 miles) every time if doing longer change cycles. Also a good dyno can tell you more about blowby it's percentage as well as how engine doing.
  10. nv1
    nv1 Bobtail Member
    16
    Mar 8, 2013
    Reno, NV
    Hey losttrucker! you started trucking 7 yrs b4 being born??!! #### fine trick!
    losttrucker Thanks this.
  11. losttrucker
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Thank You!!! It wasnt easy, let me tell you!! I knew when I was just a "twinkle" in my dads eye, I was MADE to drive a truck; so I started training right then!!
    I know, I know, you wanna hang out now BUT I am sooooo busy training for my next job in my second life that I am just too pooped!!
