Thermo king APU A/C
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Martineztrucker, May 30, 2020.
  1. Martineztrucker
    Martineztrucker Bobtail Member
    May 30, 2020
    My apu compressor kicks on and then it starts to slow down like it’s building up to much pressure I replaced the compressor and dryer and expansion valve then vacuumed the system and recharged it and it did the same thing
    Any one have an idea what it could be
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    If the pressure got to high does it not have a cut out switch?
    Could it be a fuel or other power problem with the engine?
    What are the high and low readings on the gauges?
  4. rtyauch301
    rtyauch301 Bobtail Member
    20
    Mar 29, 2011
    Athens, Alabama
    do you mean the engine rpm drops if so mine did that the lift pump failed on the apu and it couldn't get enough fuel to properly run under a load
  5. Martineztrucker
    May 30, 2020
    It doesn’t cut off
  6. Martineztrucker
    May 30, 2020
    The engine works fine till the compressor kicks in 2 mins later it starts to slow the engine down
    Motto Thanks this.
  7. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    What is the high side pressure?
    Martineztrucker Thanks this.
  8. Motto
    Motto Light Load Member
    102
    126
    Apr 10, 2020
    Your engine is not making enough power. Could be many things...
