Thermo King cab heater question
Discussion in 'Expediter and Hot Shot Trucking Forum' started by SoG444, Dec 6, 2018.
  1. SoG444
    SoG444 Light Load Member
    62
    6
    Dec 5, 2018
    Those cab heater that run on diesel fuel, how much diesel they consume a night? Do they produce a fuel smell? Any other minuses??
    Thank you!!!
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Just get an espar or webasto. With the nod going to espar. Consume like .5 gallon for 10 hours for a truck sleeper. Doesn't draw much from the battery either. Excellent way for night time heat. The standard bunk heater is what you want. Do not get the next one up, designed for box trucks. It will never get past idle and will carbon itself up. The standard bunk heater will cook you out if you crank it right up. Spring for the digital thermostat if it costs extra.
    sirjeff Thanks this.
  4. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Not much fuel and no smell needs to be serviced about once a year at least mine does , parts about 25 labour do your self half hour. Best of luck
  5. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Thermo king bunk heater will melt plastic its so hot. I know this because I left an empty coke bottle on the floor near the air outlet and when I woke up in the morning the coke bottle looked more like a drink coaster. And no, you never smell anything. You can't burn diesel and inject that into a bunk, you'd be dead in an hour. You only feel the HEAT from the combustion.
    ExOTR Thanks this.
  6. SoG444
    62
    6
    Dec 5, 2018
    I forgot to mention that I drive a Ford Transit that's been transformed into a small straight truck. Does that make a difference?
  7. SoG444
    62
    6
    Dec 5, 2018
    What do you do for AC in the summer?
  8. SoG444
    62
    6
    Dec 5, 2018
    What's the big difference between espar webasto and Thermo King besides the prices?
  9. sirjeff
    sirjeff Medium Load Member
    431
    1,227
    Dec 1, 2013
    Kootenays, British Columbia
    I recently installed a "planar 2d" which is a russian copy of the Espar unit. I paid $570 CAD to my door ($425 USD) I prefer to call it a furnace..... and it uses 1 gallon every 15 hours. Comes with a very confusing digital controller.
    Lite bug Thanks this.
  10. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    They are all the same thing. I find the espar is more robust than webasto. Not sure if thermo king is it's own brand or just remarketed one of the others.
    It doesn't matter that you drive a small van, it's all the same.
  11. SoG444
    62
    6
    Dec 5, 2018
    Thanks for your answers!!! Got another one for you: they are all heaters. What do you do in the summer to get cool air at night without running the engine?
