Thermo king inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by michaelbunt, Sep 7, 2017.
  1. michaelbunt
    michaelbunt Light Load Member
    157
    69
    Apr 25, 2013
    Ragland, Al
    my apu is a thermoking tri PAC it's a 2013 and
    It is in my 2013 peterbilt 587, the power inverter behind the passenger seat just stopped working, the display lights up, it has three dashes across it, the reset button on the outlet I reset it, I pressed the reset button on the side of the inverter also. It's a thermo king inverter that came with the apu. Any advice I checked fuses already, it's getting power to it, just nothing out the outlet. Never had a problem with it before. Every once in a while if I shut the truck off and crank it back up it would make a beeping noise and I would have to turn it off and back on for it to stop. I really hate not having a inverter for my microwave and tv. This is irritating please help lol.
  3. 86mechanic
    86mechanic Medium Load Member
    373
    62,391
    Sep 6, 2016
    Northridge, CA
    Have tried disconnecting the battery cables and letting it sit for a couple minutes.
    Then reconnect them and try it.
    That's much all you can do.
  4. michaelbunt
    157
    69
    Apr 25, 2013
    Ragland, Al
    I'll try shortly. I'll let you know how I get on. Thanks. All I should have to do is disconnect one ground correct? Also my truck is equiped with a power disconnect I could just shut the power off from the battery to the truck? But I think the inverter is wired directly to the batteries and I can't tell which cables belong to the inverter. Thermo king did the install.
  5. 86mechanic
    373
    62,391
    Sep 6, 2016
    Northridge, CA
    Yeah just disconnect the ground. Can you get to the cables at the inverter?
  6. michaelbunt
    157
    69
    Apr 25, 2013
    Ragland, Al
    There not marked at all. I've looked in the battery box, can't figure out which ones are inverter cables
  7. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    take a pic and post
    michaelbunt Thanks this.
  8. gregbo
    gregbo Light Load Member
    121
    98
    Oct 16, 2010
    Cherry Valley IL
    Three years is about the expected lifespan for an inverter in my experience. If you can fix it great but I'd be shopping for a new one. I actually carry a spare in case mine goes bad. Can't live without AC.
  9. michaelbunt
    157
    69
    Apr 25, 2013
    Ragland, Al
    I will shortly I will before I take off tonight
  10. Onetongwa
    Onetongwa Bobtail Member
    That’s ########, maybe with the cheap inverters, nobody pays top dollar for a three year inverter. And my inverter is still going strong after 4.
  11. Wickedchicken
    Wickedchicken Light Load Member
    50
    64
    Nov 6, 2020
    soo, there is not a lot of information on Thermo King Inverters. My research has shown me that previously they had an inverter that had massive recalls due to fire hazards. But when I try to research on the durability or any type of reviews ratings on the new they released on September 24 2020, I get nothing. Does anyone have any experience with Thermo King Inverters 2000W late model, please post up here. Thanks.
