Thermo King Magnum units
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Roadhound, Jan 16, 2009.
  1. Roadhound
    Roadhound Light Load Member
    283
    113
    Jan 31, 2007
    Tennessee
    This may have been discussed before, or most may already know, but for the reefer guys, stay away from the thermo king magnum. The Magnum is a screw type compressor that is designed for deep freeze applications, such as -35 degrees F. These compressors are very expensive. I just had one replaced for a grand total of $5000! The compressor was working fine, but it started leaking freon and oil around the main shaft housing, where it bolts to the engine.
    Apparantly, if the unit is ever run with out of freon, it causes the compressor housing to overheat and warp. Since these things are sealed primarily with o-rings, it is impossible to repair without replacement of the compressor. the new compressor has been redesigned due to this problem, so if you were in the market for a used reefer or unit, be wary. If the compressor has been replaced before, you might be alright, but if not, run like hell! I myself had never dealt with the magnum before, just the SB's and Super II. I just thought I would share this. I wouldn't want anyone to find out the hard way like I did.
    Baack Thanks this.
  3. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    The screw type compressors suck, magnum is a nice unit BUT when that compressor goes be prepared for a ### raping.
  4. Roadhound
    283
    113
    Jan 31, 2007
    Tennessee
    Yeah, I unfortunatly found out the hard way. But the new compressor has a 2 year warranty and has been redesigned, so if I can get another year or so service out of it, I think I'm gonna bite the bullet and replace with a new SB 210 unit. You're right though, these things work great when they're working right.
  5. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    They really do, i was going to hang a SB-III magnum on my old spread but once i heard of the troubles i decided to stay away, i guess you can put a normal piston style compressor on it. Cant you?
    I know the last one i seen brought a empty trailer to -20 in 85*F heat in about 10 minutes, my SB-III would need a good 3 hours.
