Thermo king tripac apu
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fastforward1, Jun 23, 2016.
  1. fastforward1
    fastforward1 Bobtail Member
    38
    6
    Nov 8, 2012
    Can someone explain where the reset button is. I called thermo king and they said under bunk on a black box. Only box I see is the evaporator and the tech said it's another box with white wires going to it. The space is only so big and I see no other box. Please help its hot out here
  3. fastforward1
    38
    6
    Nov 8, 2012
    BTW I am getting a ENG code
  4. FloydNasby
    FloydNasby Light Load Member
    57
    51
    Mar 19, 2015
    Austin, TX
    There's a "black box". I have to reset mine from time to time. The button is up on the side and is small. Check both your side boxes. It's in there somewhere!
  5. Dave_in_AZ
    424,508
    Cascadia?
    It's under your bunk. Drivers side. There is a black box about 12 x 12, its a white button popped out on the side, probably eye level if you pop the access door out side the truck. Press in until it clicks.
    Call TK in SLC, they are by far the most helpful, ask for service, if this doesn't work.
  6. jimjam38
    jimjam38 Medium Load Member
    458
    73
    Nov 6, 2011
    chickasha, oklahoma
    I couldn't find a black box in drivers side. Now there is an 1800 w inverter there (cane with truck) there is a power button and a select button in top of the paneling surrounding the inverter. It is one of those freedom hf 1800 models. It was showing 12.8v and all my apu will do is come on, the fan will blow and you can hear the buzzer but nothing else happens. Fan then shuts down for about ten seconds comes back on but still no apu motor. This is all brand new truck is 2017 freightliner. everything in this truck is brand new. I pulled the panel off of the interface to check fuses none were blown, apu is good on fluid and belts. Truck is idling now and the volts shot from 12.8 to 14.2 in about a minute. But when I go too shut down the truck to run apu the unit won't start.
  7. Dave_in_AZ
    424,508
    '17 EVO? EVO's are set up different. Call SLC TK service department, they talked me through several things.
    jimjam38 Thanks this.
  8. Dmj6151
    Dmj6151 Bobtail Member
    24
    Jun 21, 2016
    1. do you have a 110 v wall-plug? if yes, between the plugs there is the small reset button like you have in the bathroom plug. Press and hold that.
    2. In the bunk, left or right side, you will find a vertical box, where all the wires goes in. Somewhere on that box, it should be a small pushbutton, about 1/4 Inch rad. and 1/4 inch sticking out., It is about the size of a pen in thickness . Probably a red button. Press that, That will reset your system.
  9. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    What model TriPac do you have? The older style had a reset button on the side of a vertical box which was usually in the passenger side box. The newer Evolution model does not have that button, resets are done by turning the unit off and on at the control panel. The unit will not start if the switch on the actual TriPac engine is in the off position, which you will have to open the panel like you are checking the oil to see. If you have an Evolution with the DPF it will also not start if the regen switch is pushed down, or the toggle switch beside it is in the off position.
  10. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,679
    12,757
    Dec 15, 2014
    Charlotte, NC
    If you are getting a fault code reset it and cut the unit of and back on and see what happens.
  11. Eeyore05
    Eeyore05 Medium Load Member
    311
    287
    Nov 13, 2015
    'Sconni
    Need more info, is it the old tripartite, or the evolution? Has it run before? If so it's not the main kill switch, if not, probably the kill switch on the unit. Completely shut it down on the panel in truck try to restart.
    TROOPER to TRUCKER Thanks this.
