Thermo King Tripac Evo question: Current Charge
Discussion in 'Ask An Owner Operator' started by Blackdawgtrucker6969, Feb 1, 2026.
  1. Blackdawgtrucker6969
    Blackdawgtrucker6969 Bobtail Member
    7
    Feb 11, 2024
    My Thermo King Tripac Evolution is reading a current charge around 246 amps. This number seems to stay around 246 regardless of weather the engine is running or not. Should this number be 0 when the alternator is not running? I've noticed from videos that current charge amperage is around 10 amps normally. My Charge Current Shutoff Value is set to default 12 amps. Does anyone know what this issue is?
    Also, I have noticed when the engine starts because of low battery voltage in standby mode, it will continuously run until I manually turn off. It will not recognize when the batteries are charged and shutdown. I would like it to turn on to keep batteries charged but not overcharge.
  3. abyliks
    abyliks Road Train Member
    4,115
    9,688
    May 2, 2010
    ludlow MA
    When was the last time you cleaned the battery connections? How old are the batteries?
    86scotty Thanks this.
  4. Blackdawgtrucker6969
    7
    Feb 11, 2024
    I just got new batteries and cleaned everything up 2 months ago. I noticed before changing batteries, it would constantly charge. It would run for 24 hours if I didn't shut it down.
  5. Blackdawgtrucker6969
    7
    Feb 11, 2024
    I did replace the alternator 6 months ago. It appears to be working fine. The voltage is above 14 volts when running.
  6. 86scotty
    86scotty Road Train Member
    4,700
    12,902
    Aug 27, 2017
    Appalachia
    Surely it's just a glitch, that high of amperage isn't even possible. Stuff would be on fire.
  7. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    I’m guessing, the control module has failed, because it’s not correctly sensing voltage and amps. It shouldn’t run more than ~15min, when topping up the batteries and nothing else drawing from the system. I’d stop at your local TK dealer and ask them for an opinion. Chances are, they’ve seen it many times before.
    Speedy356 and 86scotty Thank this.
  8. Blackdawgtrucker6969
    7
    Feb 11, 2024
    It is correctly sensing voltage. Amps don't seem to change. Dealership was my last resort. Trying to see if anyone knows how to fix this. Thank you.
  9. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    Yes, it seems the module is reading it because the display voltage is seemingly accurate, but, the module must not be correctly SENSING the voltage or it would shut off the APU. Likewise, the amperage reading is erroneous. You’ve got two wrongs related to electricity, which makes me think it’s the module.
    Anytime unexplainable/random things are happening and there’s a module involved, the module is usually the failure point.
  10. Blackdawgtrucker6969
    7
    Feb 11, 2024
    Thanks, my fear was it's the control module. Already replaced it once on this unit and unit only has 4600 hours. First time was under warranty. Thermo King is such garbage and the parts are so expensive.
    xsetra and ducnut Thank this.
  11. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    I agree. I think, their stuff is overrated and they’re just resting on the laurels of their name. We have tons of issues with our TK APU’s, as well. What’s worse is the dealer stocks very little for them.
