Thermoking Evolution USB Connection
Discussion in 'Ask An Owner Operator' started by OTR--247, Sep 21, 2025.
  1. OTR--247
    OTR--247 Bobtail Member
    46
    25
    Apr 27, 2010
    La Luna, Valencia
    So little blue bill got one.
    And you can't find TSA info Donwload/Center /evolution bla,bla any where in the web, neither Service Tool R2 download.
    Diesel Laptop download either.
    But a 2013 windows vista laptop worked like a charm. Just plug and play. W 7, 8 and early version of W10 work too.
    So happy than even check the fault code.
    My Evo click the fuel pump and the buzzer but no crank at all, if some one got and idea let me know. Already change the rocker switch, belts, filters, condenser and radiator fans, clean alternator connections and grounds on apu and ground in the control box inside bunk, fuses at the battery box and 50 amp and 3 amp fuse at the apu.Thanks.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,015
    2,086
    Dec 15, 2021
    Look for a small wire going down to the starter,it bolts on right with the big starter wire.The small wire usaully breaks,then it won't start.Happened to mine and another driver.
    Friend, OTR--247 and D.Tibbitt Thank this.
  4. North Pole Nightmare
    1,015
    2,086
    Dec 15, 2021
    After I got it running, got a code for cabin temperature sensor,it was about $800 for that.
    Friend and D.Tibbitt Thank this.
  5. D.Tibbitt
    157,230
    Can add me to that list of people that had that happen... that was frustrating trying to find what the hell the problem was til i went to move that wire out of the way and found it was rubbed thru
    Friend Thanks this.
  6. OTR--247
    46
    25
    Apr 27, 2010
    La Luna, Valencia
    Will do next Saturday, I got to remove quarter fender and side panel just to get a better look at it
  7. OTR--247
    46
    25
    Apr 27, 2010
    La Luna, Valencia
    Yesterday play a little with the apu
    Red triangle ️, ALT, code 61.
  8. North Pole Nightmare
    1,015
    2,086
    Dec 15, 2021
    That small wire is the one that picks up the voltage signal,it's probably broken or rubbed through.
  9. OTR--247
    46
    25
    Apr 27, 2010
    La Luna, Valencia
  10. OTR--247
    46
    25
    Apr 27, 2010
    La Luna, Valencia
    Was rough today, freezer ice bin froze, washer machine broke having a beer now.
    Well got 2 broken wires the white coming together with the red one from truck battery positive ( 2A) just behind the apu by the frame and the blue terminal at the alternator, still no crank. Cheers
    D.Tibbitt Thanks this.
  11. North Pole Nightmare
    1,015
    2,086
    Dec 15, 2021
    Might have to stop in at a TK shop,have them check it out.I got mine running but it was blowing warm air instead of AC.
    Took it in to the shop in Houston,the cabin temp sensor was bad they changed the control box under the bunk and fixed it.Very good diagnostic and repair price.
    I was at the terminal in Louisville,talking to another driver about the APU,he said the little wire was broken on his.I went out to my truck and looked,sure enough the little wire was broken on mine too.
