Volvo d13 oil thermostat code showed up in the engine light. Replaced thermostat and the engine light is back again for the same code. Any suggestions ?
Was that the Oil temp thermostat or coolant antifreeze? Either way after the replacement you need to delete/erase the codes.
It was the oil temperature thermostat. The gauge seemed to work after replacement but now it looks kind of stuck though.
