Thermoster mod
Discussion in 'International Forum' started by earnies2, Sep 30, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    Ok here is my fix for the thermoster replacements.
    I used 2 old thermosters and gutted them. Then I got a 90° hydraulic fitting and cut off the threads. I also got 2 12mx1 nuts. And welded the pieces together. The gutted thermosters act as plugs and the nuts are to put new thermosters in, I also added some heat transfer paste in the fittings. Lastly I plan on heatshrinking the fittings and adding some pipe insulation over that. So now when I change out the thermosters I don't need to vac and refill the system..
    Heavyd and QUALITYTRUCK Thank this.
  3. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Nice! You're hired!
    earnies2 Thanks this.
  4. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Thanks I was frustrated that you needed to recover and vac the system out to change the thermosters. And I ended up with a couple of bad sets. So I figured it out.
    I just love mods.....
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Good job. Necessity is the mother of invention
  6. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Update I vacuumed it down and gassed it up and she is ice cold.
    I also have a 12 volt ball valve for a heater control valve.
    Heavyd and InTooDeep Thank this.
