Thermosters
Discussion in 'International Forum' started by earnies2, Jul 20, 2019.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    Is there anything I can do to make them last over 2 months?????
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Thermostats? Engine overheating? On my cat they replaced the housing they fit in. It was pitted, and rough. Just done a few months ago, so we will see. How old is engine? What kind?
    pavrom Thanks this.
  4. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    The thermisters on the AC on a international prostar
    stillwurkin Thanks this.
  5. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Mayby you already did..but i googled thermisters. Old posts came up, i think 2016, or 15, that may help you out?
  6. Heavyd
    Heavyd Road Train Member
    7,767
    6,204
    Feb 4, 2009
    Should be 1 year parts and labour warranty if any decent shop installed those for you. If you continue to have repeat failures, I would say you have a wiring or connector problem that is corrected when new sensors are install and gradually fail again due to wear connector pins or semi broken wire.
    earnies2 and brian991219 Thank this.
  7. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I installed them myself I purchased 2 sets on Ryder fleet products i purchased them over a year ago to have them in stock....
  8. Heavyd
    7,767
    6,204
    Feb 4, 2009
    Ok, that might be the problem. International did a couple of updates on them because there were bad designs and then a huge bad batch a few years ago. I suggest your next set should be genuine International ones from your local dealer. I know they are probably more money, but better than messing around all the time like this.
  9. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Ok sounds like a plan thanks
