Thick Coolant in Volvo D13 engine?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Stringb8n, Jan 16, 2024.
  1. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Oddly enough it can also go slushy if it was almost straight antifreeze without added water.
    Also if the types of antifreeze are mixed it can cause thickening or gelling. Be sure to put in the type recommended by the manufacturer.
    Generally I bought premixed then I didn’t have to worry about getting the proportions right.
    Stringb8n Thanks this.
  3. Stringb8n
    Stringb8n Road Train Member
    1,628
    2,095
    Sep 27, 2015
    I just went out to walk the dog and raised the hood again and put some umph into moving the coolant tank, and the coolant moved. So it isn't frozen and didn't appear to be gelled either. Thank goodness. I thought I was going to have some serious issues on my hand. Guess I didn't eat my wheaties, or I was too worried about the cold splitting my delicate little girl hands if I pushed too hard.
    KB3MMX Thanks this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    First step is testing...
    And if you're running subzero you should be setting your coolant between 60-70% for maximum protection in these -20 to -40 temps out west
    This is true!
    Do not exceed 70% coolant ...things start going backwards...
    Do not mix green coolant with red ... It will destroy your cooling system.
    If you suspect it's gotten mixed... It needs flushed out properly and refilled.
