Tight Construction lanes and maintaining control?
Discussion in 'Questions From New Drivers' started by TravR1, Oct 6, 2018.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,783
    Nov 9, 2017
    TX
    So I went through Tennessee this morning and had a he'll of a time with it. It was one of those deals where the lanes were curve and it had the freeway dividers right on the white lines. Little room for error or compensation for offtracking on curves.
    Anyway the limit was 55 and I decided to take it at 50 knowing my tendency to drift to the right some. Of course the trucker behind me wanted to pass me. He had the dividers on his side to the left. So i didn't want to smack mirrors with him so I turn off my Bendix and get as far right as i could on the white line. Well the road was fresh paved so there was a drop off about maybe an inch or two. That caused a pull to the right, then I compensate and pull right on steer then it pulls me left again.
    End result was me doing that over and over again like a snake on the road playing Russian roulette with the ditch to my right. 15 minutes later i pass another truck that was in a ditch!
    How do y'all handle those situations without compromising control like that? I did it again passing on the left too. I was surprised those small changes in height have such an effect. It felt like my left side got blasted with wind all of the sudden.. And I was only doing 50-55. Is it a good idea to try and give space like I did or better to keep it centered? How to handle dips in roads without turning into a snake? I tried to compensate and keep it steady but felt like the dip pulled me every time I tried to pull back up it would pull me back down. It sucked I felt my stomach drop into my guts when it happened. I was lucky I didn't lose control and roll over or fly in a ditch like that other truck.
    Fuelinmyveins and Lepton1 Thank this.
  3. Chinatown
    Chinatown Road Train Member
    77,852
    184,947
    Aug 28, 2011
    Henderson, NV & Orient
    Keep it centered; ignore the trucker behind you; your job is on the line, not his. His life won't change just because he's delayed less than a minute.
  4. WesternPlains
    6,369
    57,406
    Sep 1, 2017
    Rapid City, SD
    Slower... When you can maneuver over those little drop offs with no lunging. Then you're doing it safe.
  5. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    That's easy to say but invariably the trucker behind is going to pass. And your keeping "centered" and his possible poor driving skills are going to result in bad things happening, sooner or later.
    You have to do what the situation allows. Always give yourself extra insurance IF POSSIBLE [without risking your safety]. I will try and go through at a speed that's practical and that may prevent the guy behind from getting impatient and passing. These narrow, shifting construction zones are a danger and you just have to deal with them as they come. But if we're talking about a significant drop off into a dangerous culvert, you have to allow yourself some safety allowance room.
    If you can see the problem zone ends soon ahead. Straddle the center line and don't give idiots room to pass and show how stupid and impatient they are. But at least try to drive the construction speed limit if otherwise conditions allow.
    Eowyn, Lepton1, TravR1 and 2 others Thank this.
  6. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    I always say that if you cannot control yourself in your lane then you are going to fast. Construction or not. To hell with the guy behind you. If he wants to chat about it I'd be happy to pull over and give my opinion to him. Just sayin'
  7. Espressolane
    18,711
    117,316
    Sounds a bit snarky at first. Drive your truck, I’ll drive mine. You control your truck, if you need to slow to keep control in an area that is under construction, then do it.
    Do your best to maintain your lane as centered as possible for conditions. As to the other trucks and autos around. Not your direct worry. Know that they are around you, but thats about it. Get down the road safely.
  8. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Unfortunately a lot of Truckers will do that to you. I’ve had it done to me. Sometimes faster is never fast enough. They have to pass you. A lot have governed Trucks and are trying not to lose time.Expierience teaches that you really don’t get very far ahead.I do what’s gonna keep Me from causing an accident.Usually if they’re in hammer lane already in violation. Cause a wreck it’s their ticket.Be safe hold it steady look out for yourself and don’t run with the crowd. Sometimes they get a little closer than they wanted all tangled up blaming each other for the wreck
    TravR1 Thanks this.
  9. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    As others have said above. Worry about your truck. I also can appreciate your concern for not wanting to be the guy holding up 5 miles of traffic.
    If the situation comes again and that other driver is feeling froggy enough to pass on the left. He will move left and start nosing in on you. It would be best to give as much room as you can safely, and back your speed down a couple mph to let him get by you. It's better to do that than let him wreck the both of you.
    Otherwise if he is staying behind you don't worry, and get through it safely. I'm sure he would rather you hold him up a few minutes, and get through it safely. Than you to roll it over and shut him down for hours.
    TravR1 Thanks this.
  10. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
  11. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Sometimes faster is better. Like changing lanes when there is a snow pile sitting on the edge of each rut. You want to get through it somewhat aggressively so it dosn't take over and do the steering for you.
    Pull the band aid off fast.
    wore out, Lepton1 and J Rich Thank this.
