Tips for cracking the frame
Discussion in 'Flatbed Trucking Forum' started by Old Hullabaloo, Apr 11, 2019.
  1. Old Hullabaloo
    Old Hullabaloo Bobtail Member
    27
    22
    Feb 25, 2019
    What are the best ways to crack one's frame... and how to avoid doing that?
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Just wait he'll be here shortly.
    Don't over load it, would be top of the list
    D.Tibbitt, MACK E-6, Tb0n3 and 4 others Thank this.
  4. Old Hullabaloo
    27
    22
    Feb 25, 2019
    Are there bad ways to park, like on unlevel ground?
  5. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    If'n you chain the front of your frame rails to the ground, chain the rear of your frame rails to the ground... Then get yourself a air over hydraulic bottle jack, and a comfortable creeper to lounge on while you work. If you run the jack out till it stops, and then release it... and repeat.
    That's probably the easiest way to crack it without wrecking anything else.
    PPLC, SAR, snowman_w900 and 3 others Thank this.
  6. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    What is it you are trying to accomplish?
    Frames can take a lot of abuse. Whether single or double. After many years it may crack or it may not. Just the way it is. It can possibly be fixed or it may need to be reframed. Parking on level or uneven ground isn’t gonna net you more years. Just drive the truck dude. No matter what you do, you aren’t gonna prevent the frame from cracking if it decides to do that in a few yeats
    Grubby and Bean Jr. Thank this.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Drive up north and NEVER wash it. Mother Nature will do the rest. Give her time.
    D.Tibbitt, Grubby, Brettj3876 and 3 others Thank this.
  8. rbrtwbstr
    rbrtwbstr Road Train Member
    3,399
    7,925
    Jul 11, 2012
    in the bush somewhere
    Just take a ride down Route 222 from Allentown to Lancaster. After a few trips, you should encounter broken springs, blown out shocks, and maybe even a cracked frame.
  9. bzinger
    bzinger Road Train Member
    16,647
    66,148
    Dec 10, 2014
    omaha , ne
    Or 70 in Indiana.
    D.Tibbitt, Buc, PPLC and 3 others Thank this.
  10. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    On a Reitnouer spread axle step deck? Dump the air from the rear axle while loaded.
  11. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    That ain't no shit!
    jamespmack, PoleCrusher, cke and 6 others Thank this.
