Tips on tracing wires from a switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cajuncowboy654, Jul 5, 2019.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    Any tips or tricks to tracing where a switch leads to?
    Have a dump valve switch on the dash of my 05 379. It's a factory installed switch and has a red light that comes on when it is switched on.
    I tested the pigtail to the trailer but the center pin which is normally used is always hot so I'm guessing abs.
    Any idea where else this switch wiring may lead? Or tricks to find it?
  3. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    Best bet would be to pull the switch out of the dash and see if there are any wires other than one (dash light/keyed power) and go from there.
    Other than doing that, your best bet would be to literally follow the wires around. You could take a multi meter and test for resistance on suspected wires to see if there’s any continuity from point a to b.
    FlaSwampRat Thanks this.
  4. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    That's what I was thinking. If he thinks it's a trailer dump valve start continuity testing between the switch and the pigtail and hope for a hit.
  5. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Thanks, its definitely not at the pigtail. Tested the pigtail and every pin is as it should be with the center always hit for abs.
    There is a dash light, will have to pull the dash and see if I can follow it
