Tire Changing
Discussion in 'Ask An Owner Operator' started by Mmorales95, Jun 4, 2020.
  1. Mmorales95
    Mmorales95 Bobtail Member
    5
    What would you guys recommend I purchase so that I can replace flats on my rig. I seen some use cordless tools and I see others using air tools. What has been the best experience for some of you guys. Also recommendations for jacks and bead breakers?
  3. mojo2010
    mojo2010 Bobtail Member
    35
    16
    Mar 7, 2014
    I've used those push plugs in tires while out and then patch when back home. Gladhand air hose, plug kit. Ive used a jack but prefer to drive up on dunnage if possible to lift the flat tire. Main thing is to Try to catch a leak before it gets bad.
    PE_T Thanks this.
  4. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Where do you get those plugs?
  5. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    On the road or at home? On the road a plug kit and an air hose with glad hand end is worth alot. Need to catch it before you break the bead though.
    PE_T and stillwurkin Thank this.
  6. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    get only the red plugs
    HopeOverMope Thanks this.
  7. TJB15
    67
    115
    Apr 29, 2020
    You can buy a plug kit at most truck dealers or truck parts suppliers.
    PE_T and Dino soar Thank this.
  8. TJB15
    67
    115
    Apr 29, 2020
    Also would recommend a good pair of side cutters to remove whatever made the hole.
    Bean Jr. and Dino soar Thank this.
  9. jinxutoo
    jinxutoo Light Load Member
    134
    224
    Jan 17, 2012
    Illinois
    I get my plug kits from fleetpride for use on the road, along with the tools mentioned above.
    The tools and plugs I have at home are just like what the truckstops use, also purchased at fleetpride.
    If you're running low on plugs you can usually give the tire guys at the truckstops a few bucks for a handful of them.
    PE_T Thanks this.
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Had a half-inch wrench that I pulled out of one of my truck tires.
    I just double plugged it...
    But yes cutters work great..
  11. 201
    201 Road Train Member
    12,817
    26,390
    Apr 16, 2014
    high plains colorado
    Where are you getting all the flats? Breaking the bead is the biggest problem. On the farm, we used the outrigger on the backhoe. If your name is Jethro Bodine, you can get one of those bead breaker sledges, but unless you do a lot of tire changing, just take it to a tire shop.
    86scotty Thanks this.
