Showing my lack of knowledge, what is considered tire wear vs damage?
In other words, what does DOT look for beyond tread depth? I've sent in a few DVIRs for a few tires I thought were bad but got push back from corporate Roadside bean counters.
These were approved for replacement.
Tire Damage or just worn?
Discussion in 'Questions From New Drivers' started by RollinChaos, May 3, 2025.
Reason for edit: Edit: clarifyhope not dumb twucker Thanks this. -
Meant to add if I am unsure I will send pics with a penny stuffed inside the cut or to show the lack of tread depth
Bottom one definitely NFG in my opinion, the cap looks like it's starting to seperate from the casing. Depending how deep the gash is in the sidewall would be the deciding factor for me.
Get yourself a tread gauge tool and then you can send them the actually measurement. 2/32" on drives and trailer, 4/32" on steers IIRC.Sirscrapntruckalot, Sons Hero, Bean Jr. and 4 others Thank this. -
Sidewall cuts are most common issue I see. Is there a guideline on what is allowed? Or it all depends on the inspectors quota at the moment?
No mention of sidewall
first is curb damage. that tire came into contact with something, second looks like a bad recapp.Sons Hero, Albertaflatbed and 201 Thank this.
Yeah, you cannot have a damaged sidewall, that first tire needs to be replaced, the second without being touch close to really see it, it very well may pass DOT, but personally I would have it replaced. If the company won't replace it, it would be a shame if it deveploed sidewall damage, not suggesting just saying what a shame it would be.D.Tibbitt, hope not dumb twucker, Rugerfan and 2 others Thank this.
My understanding on sidewall damage is, if you can see any steel cords, it’s out of service if the DOT see it.
hope not dumb twucker and Bean Jr. Thank this. -
Thanks for the comments, much appreciated.
I will continue to report anything via DVIR that looks out of normal.
Prior to posting the initial question and just now I have not found any clear guidance on a FMCSA page that defines what amount of sidewall damage would require replacement.
