Tire pressure management systems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Mar 4, 2023.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    On a trailer equipped with an auto inflation system, is there an easy way for a driver to test for proper functionality?
  3. Kyle G.
    Kyle G. Road Train Member
    3,902
    20,578
    Jan 23, 2016
    Eastern Iowa
    062 Road Train Member
    6,333
    33,972
    Oct 20, 2013
  5. Star Rider
    Star Rider Road Train Member
    1,789
    18,680
    Sep 23, 2019
    Thumping a tire with a hammer has worked well for a long , long time , just sayin'
  6. krupa530
    krupa530 Light Load Member
    296
    1,140
    Dec 3, 2014
    Orem, UT
    You can put internal tire sensors in them. Keep your eye on all the pressures, and temperatures. I have the tiremaxx pro installed for inflate and deflate, and it’s nice to see the system working correctly. All eight wheels at the same pressure all the time. I put the internal sensors in running a tst tpms system.
  7. Commuter69
    1,142
    635
    Jul 2, 2014
    All these methods are great at finding problems that actually exist. But what I am looking for is a way to test the unit to detect a problem in the making when I might pick up something more than was planned that actually punctures a tire, making sure that the system actually works as designed. On one occasion, I picked up a 4" pocket knife blade that worked itself into the tread, another time I picked up a 2" square piece of a broken metal file! I've also picked up nails and a bolt or two..... aaaaarrrrrggggghhhhh!
    These systems are valuable tools when they do what they are designed to.
    Yes, I have a pressure gauge, and a handheld sledgehammer (maybe 3 pounds), as well as a tread depth gauge in my toolkit.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Another Canadian driver and Oxbow Thank this.
  9. Last Call
    7,568
    45,913
    Mar 15, 2021
    He's pretty busy right now looking for a set of matching...[ air inlet port cap]
    Or he might think about starting a thread ..[ How do you set the blinker timer ]
  10. 062
    6,333
    33,972
    Oct 20, 2013
    For you.. ugh I mean for your friend. Most anything is a crack pipeo_O
  11. tscottme
    tscottme Road Train Member
    I would hook up the airlines & pigtail then charge the trailer brakes. If the light on the front left corner goes out it means the auto inflation has stopped adding air. That's all I knew to do for it.
